BGP bandwidth consumption
avillalva
Hi all,
I'm trying to calculate our BGP bandwidth consumption. In RFC 1774 the formula is MR = O(N + M * A) (http://tools.ietf.org/html/rfc1774)
My question is…what is 'O' ??
thanks very much,
Andres
harish.ab
not much sure.. but I think it is '4' byte AS number..
Giuseppe Larosa
Hello Andres,
usually O is a math symbol and means proportional to the formula inside ()
here:
N= number of routes in internet
A= total number of ASes in internet
M= average AS path length = average AS distance
try to make the calculations in the example you will see a factor something less 4
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for the response. After your comment and a conversation with a colleague yesterday I am satisfied the O is Big-O notation.
Some things still don't make sense... the answer I get in example 1. 10000, 15, 300 is "in the order of" (Big O) 14500. Why is there a factor of 3.7 or so to derive the Bandwidth? where did this come from?
Also, none of the variables are in Bytes but the answer is in bytes. Where did those units appear from?
Andres
