bgp bestpath as-path multipath-relax and IPv6
jni
Hello
Quick question.
I know bgp bestpath as-path multipath-relax is working for IPv4, but what about IPv6 route loadbalancing?
I did lab it in GNS3, but it didn't give the expected output for IPv6.
For IPv4 before/after implementation of bgp bestpath as-path multipath-relax
#show ip bgp 0.0.0.0
BGP routing tshow ip bgp 0.0.0.0 able entry for 0.0.0.0/0, version 21
Paths: (3 available, best #2, table Default-IP-Routing-Table)
Flag: 0x840
  Advertised to update-groups:
        1    2
  200, (received & used)
    200.200.200.1 from 200.200.200.1 (200.200.200.1)
      Origin IGP, metric 0, localpref 100, valid, external
  100, (received & used)
    100.100.100.1 from 100.100.100.1 (100.100.100.1)
      Origin IGP, metric 0, localpref 100, valid, external, best
BGP routing table entry for 0.0.0.0/0, version 30
Multipath: eBGP
        1    2
      Origin IGP, metric 0, localpref 100, valid, external, multipath
      Origin IGP, metric 0, localpref 100, valid, external, multipath, best
But if I try the same for IPv6 I see no difference in output before/after
#sh bgp ipv6 unicast ::/0
BGP routing table entry for ::/0, version 2
Paths: (3 available, best #2, table Global-IPv6-Table)
        1    2
  200
    2200::1 (FE80::C005:9DFF:FEAF:1) from 2200::1 (200.200.200.1)
  100
    1100::1 (FE80::C004:9DFF:FE90:1) from 1100::1 (100.100.100.1)
Paths: (2 available, best #2, table Global-IPv6-Table)
        1	2
  200
  100
Is this a GNS3 issue, doesn't it work for IPv6 or is it just me :o)
Thank you in advance.
2 Accepted Solutions
Giuseppe Larosa
Hello @jni ,
can you post the configuration of your router , at least the router BGP section ?
Have you applied the command ar router bgp level or within an address family ?
ipv4 unicast
ipv6 unicast
It can also be a limitation of GNS3, but more info is needed to provide some help.
Hope to help
Giuseppe
jni
Argh... my own fault
I forgot to add maximum-paths under the ipv6 address-family. This of course has to be added under each address-family. My bad.
Giuseppe Larosa
Hello @jni ,
ipv4 unicast
ipv6 unicast
Hope to help
Giuseppe
Since you where the only one to reply, and that you probably would have spottet the error when I posted the configuration, I accept your answer (but as I stated I didn't state maximum-paths under address-family ipv6)
Hello @jni ,
when dealing with MP BGP most of the commands become per address family,
So my suggestion was a guess of what could be the most reasonable cause of the issue based on experience.
I'm happy to have been of help
Best Regards
Giuseppe
jni
