BGP / CCNP R&S ROUTE: Implementing IP Routing
JMarquez99
If our goal is to aggregate 2001:0DB8:0:0::/64 to 2001:0DB8:0:35::/64 as a single, summarized route, write the full aggregation command to perform this.
Router(config-router)#
JMarquez99
Does anyone know what will be the full aggregation command to perform this?
Hoping to have your feedback
TIA
Giuseppe Larosa
Hello @JMarquez99 ,
you can aggregate checking the bits or hexadecimal digits in common.
Hex 35 -> 00|110101
Hex 00 -> 00|000000
You need to shrink the prefix length of six binary digits so your aggregate address will be
aggregate-address 2001:0DB8:0:0::/58
and will cover subnets up to 2001:0DB8:0:3F::/64.
So this is an approximate solution called in some books an inclusive summary route as it includes some additional subnets.
Hope to help
Giuseppe
I believe the following command can help you
Please do not hesitate to click the STAR button if you are satisfied with my answer.
