BGP community strings getting converted to decimal
johnnylingo
Level 5
Level 5
I've noticed in IOS 15.x routers, community strings are getting converted to decimal after being entered:
Router(config)#route-map BGP per 10
Router(config-route-map)#set community 65535:12345
Router(config-route-map)#do show route-map BGP
route-map BGP, permit, sequence 10
  Match clauses:
  Set clauses:
    community 4294914105
  Policy routing matches: 0 packets, 0 bytes
Is there a setting that will keep them as strings, just as entered?  That's what our older routers running 12.x do.
Vinit Jain
can you configure "ip bgp-community new-format" in global config. seems you are missing this config.
--Vinit
Vinit Jain
--Vinit
Yep, that did it.
