bgp community
bmuggall
   I was trying the following scenario in my GNS simulator. I could not see bgp community attribute taking effect. Please let me know what is going wrong here.
|R7|------|R5|
R7:
router bgp 200
no synchronization
bgp log-neighbor-changes
network 70.1.1.0 mask 255.255.255.0
network 70.1.2.0 mask 255.255.255.0
aggregate-address 70.1.0.0 255.255.252.0
neighbor 5.5.5.5 remote-as 100
neighbor 5.5.5.5 ebgp-multihop 2
neighbor 5.5.5.5 update-source Loopback0
neighbor 5.5.5.5 next-hop-self
neighbor 5.5.5.5 route-map lab_3 out
auto-summary
R7#show route-map lab_3
route-map lab_3, permit, sequence 10
  Match clauses:
    ip address (access-lists): 106
  Set clauses:
    community no-export
  Policy routing matches: 0 packets, 0 bytes
route-map lab_3, permit, sequence 20
  Match clauses:
  Set clauses:
    community none
R7#
R7#
R7#show ip access
R7#show ip access-lists 106
Extended IP access list 106
    10 permit ip 70.1.0.0 0.0.3.255 any (3 matches)
R7#
R5:
router bgp 100
no synchronization
network 40.1.1.0
network 40.1.1.0 mask 255.255.255.0
network 100.0.0.0
network 112.1.1.0
network 112.1.1.0 mask 255.255.255.0
neighbor 7.7.7.7 remote-as 200
neighbor 7.7.7.7 ebgp-multihop 2
neighbor 7.7.7.7 update-source Loopback0
neighbor 20.1.1.1 remote-as 100
neighbor 30.1.1.1 remote-as 100
neighbor 30.1.1.1 next-hop-self
auto-summary
R5#show ip bgp
BGP table version is 395, local router ID is 40.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*>i20.1.1.0/24      30.1.1.1                 0    100      0 i
r>i30.1.1.0/24      30.1.1.1                 0    100      0 i
*> 40.1.1.0/24      0.0.0.0                  0         32768 i
*> 70.1.0.0/22      7.7.7.7                  0             0 200 i
*> 70.1.1.0/24      7.7.7.7                  0             0 200 i
*> 70.1.2.0/24      7.7.7.7                  0             0 200 i
*> 100.0.0.0        40.1.1.2                 0         32768 i
*> 112.1.1.0/24     0.0.0.0                  0         32768 i
R5#
R5#
R5#show ip bgp community
R5#
As shown above, I am  not seeing community attribute on R5 even when I configured route-map on R7. Could you please let me know your thoughts on this.
cadet alain
by default the router doesn't send the community attribute, you must issue neighbor x.x.x.x  send-community  command.
Regards.
Alain
Thats great. That solved the issue. Thanks a lot.
