BGP Conditional Advertisement Query
mvsheik123
Level 7
Level 7
Hi all,
We have 2 edge routers ebgp peering with 2 ISPS (primary & backup). ASPath condition on second ISP still showing some incoming traffic. But I want secondary to be pure backup.ISPs do nt support communities. So Iam looking at 'conditional ' advt.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094309.shtml
Iam wondering how I can apply in my scenario. ISP1 & 2 assgned us with /27 for LAN, but we are using/advertising our own (6.9.6.0/24) subnet. The ' ip route' from both rtrs:
Primary:
Gateway of last resort is 27.10.6.48 to network 0.0.0.0
15.35.14.0/27 is subnetted, 1 subnets
B 15.35.14.0 [200/0] via 6.9.6.2, 6w3d
27.10.9.0/32 is subnetted, 2 subnets
S 27.10.6.49 [1/0] via 8.21.9.101
S 27.10.6.48 [1/0] via 8.21.9.101
6.0.0.0/24 is subnetted, 1 subnets
C 6.9.6.0 is directly connected, FastEthernet0/0
8.0.0.0/30 is subnetted, 1 subnets
C 8.21.9.100 is directly connected, FastEthernet0/1
B* 0.0.0.0/0 [20/0] via 27.10.6.48, 2w1d
Backup:
Gateway of last resort is 23.23.53.17 to network 0.0.0.0
S 15.35.14.0 is directly connected, Null0
23.23.53.0/30 is subnetted, 1 subnets
C 23.23.53.16 is directly connected, Serial0/2/0
B* 0.0.0.0/0 [20/0] via 23.23.53.17, 6w3d
We are receiving default route from carriers. I might be wrong here, but from the above o/p, I think, we are not receving any routes from ISP1 to add conditional advt config. Please suggest.
Thank you
MS
Giuseppe Larosa
Hello Mehboob,
in the last example in the document you linked there is a interesting suggestion:
to add a match as-path to the route-map so that you can check if a route is lost from a specific neighbor
in your case you need to build
route-map NON-EXIST permit 10
match ip address prefix-list only-default
match as-path 1
ip as-path access-list 1 permit ^AS_ISP1
ip prefix-list only-default permit 0.0.0.0/0
route-map ADVERTISE permit 10
match ip address 60
to be used on neighbor to ISP2
Hope to help
Giuseppe
Thank you for your reply. I actually did some more research on this I was thinking of doing with the default route advertisement. I found a good link explains the same with configs..:
http://ciscoconfigs.net/index.php?option=com_content&task=view&id=26&Itemid=29
In the backup rtr(connecting to 2nd ISP) Iam seeing a default route learned with path info having primary ISP AS# (due to IBGP between rtrs).
* i0.0.0.0 6.9.6.3 0 100 0 2050 i
So iam planning to add a 'conditional config' based on this.(as long as RTR2 learning 0.0.0.0 with AS#ISP1 do not advertise my nw to ISP2). I think that helps.
Thank you for your quick reply and suggestion.
MS
