OSPF Areo 0 and Virtual links
The_guroo_2
Level 2
Level 2
guys basic question abt ospf virtual links.....for exaple three routers are connected A,B,C And B router serials are connected and are in areo the fethernet of the routers are in area 10 so do we need virtual connection to area 0 or not if yes why if not why??? whats the rule of thumb for virtual links......
andrew.prince
Level 10
Level 10
Jon Marshall
In OSPF all areas in the same AS must be physically connected to area 0 so a router (ABR - Area Border Router) that connects area 0 to area 10 for example would have at least one interface in area 0 and one interface in area 10.
Virtual links are used when there is no physical connection to area 0. See this attached doc for more details
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094aaa.shtml#virtuallinks
Note that virtual links are not good design. They are usually used as a temporary stop gap.
Jon
paul.matthews
Level 5
Level 5
Your question is not totally clear. The basic OSPF rule is that all areas shall be connected to the backbone. If you have an area that does not have a direct connection to the backbone, to allow connectivity to other areas you would need to configure a virtual link.
The rule of thumb for virtual links? They are for emergencies, temporary use or for people that cannot design networks.
