BGP config (2 routers, 1 ISP per router)
Peter Valdes
Level 3
Level 3
Hi Cisco,
Im new to routing and need help preparing a config for 2 routers.
We have 2 offices next to each other connected via a Layer 2 point to point access link. Each offices have a router running connected to separate ISP AS. Each offices have unique public and private IP Addresses.
I need to have BGP running on both sites so if ISP 2 fails in office 2 (ATLAS), it's public IP Address will be routed to and from ISP 1 via office 1 and default router traffic for office 2 (ATLAS) will use the L2 point to point link to get to the Internet via office 1 (NEXUS) link. Same scenerio with ISP 1 failing in office 1 (NEXUS).
NEXUS
interface GigabitEthernet0/0
description LINK TO ISP 1
bandwidth 10240
ip address X.X.X.2 255.255.255.252
ip nat outside
interface GigabitEthernet0/1
description LINK TO SWITCH STACK
no ip address
interface GigabitEthernet0/1.101
description LINK TO OFFICE 1 LAN
encapsulation dot1Q 101
ip nat inside
interface FastEthernet1/1
description LINK TO OFFICE 2
bandwidth 102400
ip address 172.17.0.1 255.255.255.252
router bgp 300
bgp log-neighbor-changes
neighbor X.X.X.1 remote-as 100
address-family ipv4
neighbor X.X.X.1 activate
neighbor X.X.X.1 soft-reconfiguration inbound
no auto-summary
no synchronization
network 61.1.1.0 mask 255.255.255.0
exit-address-family
ip route 192.168.2.0 255.255.255.0 172.17.0.2 name OFFICE2_ATLAS
ip route 61.1.1.0 255.255.255.0 Null0 200 name NEXUS_BGP
ATLAS
description LINK TO ISP 2
bandwidth 10240
ip address Y.Y.Y.2 255.255.255.0
ip nat outside
no ip address
description LINK TO OFFICE 2 LAN
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface FastEthernet0/0/0
bandwidth 102400
ip address 172.17.0.2 255.255.255.252
router bgp 300
neighbor Y.Y.Y.1 remote-as 200
neighbor Y.Y.Y.1 ebgp-multihop 2
neighbor Y.Y.Y.1 update-source GigabitEthernet0/0
address-family ipv4
  neighbor Y.Y.Y.1 activate
  neighbor Y.Y.Y.1 soft-reconfiguration inbound
  no auto-summary
  no synchronization
  network 61.2.2.0 mask 255.255.255.0
exit-address-family
ip route 192.168.1.0 255.255.255.0 172.17.0.1 name OFFICE1_NEXUS
ip route 61.2.2.0 255.255.255.0 Null0 200 name ATLAS_BGP
Help please.
30 Replies 30
Hi Val,
Kindly share the timelines(IST) of your activity, I would like to join you online so that in case of any issues we can trouble shoot.
Please consider implementing M-HSRP for lan redundancy.
Thanks.
Ameya
Hi Ameya,
Its on the 25th September @ 6AM to 8AM AEST.
I will post if I need help.
WIth M-HSRP, I dont see any benefits on our current Nexus/Atlas setup. Please explain otherwise.
Dear Val,
Only benifit is lightning convergence and uninterrupted service during BGP failover.
It is perfectly alright if not applied.
Please rate if helpful.
Thanks.
Ameya
I have one more question, I need to understand how Norwest Internet link will know of Atlas Public IP during failover if Norwest router is not advertising 61.2.2.0/24 on the BGP network?
Scenerio:
Attached previous network diagram, Atlas Internet fails. Base on the final config below, how will ISP1 know about 61.2.2.0/24 to route down traffic via Norwest link -> point to point -> Atlas LAN?
I understand everything else with the route-map prepend and prefix...
THANKS AGAIN!!!
NEXUS
router bgp 300
neighbor 172.17.0.2 remote-as 300
address-family ipv4
  neighbor X.X.X.1 prefix-list BLOCKINBOUNDBGP in
  neighbor X.X.X.1 route-map Nexus out
  neighbor 172.17.0.2 activate
  no auto-summary
  no synchronization
exit-address-family
ip prefix-list BLOCKINBOUNDBGP seq 10 permit 0.0.0.0/0
ip prefix-list BLOCKOUTBOUNDBGP1 seq 10 permit 61.1.1.0/24
ip prefix-list BLOCKOUTBOUNDBGP2 seq 10 permit 61.2.2.0/24
route-map Nexus permit 10
match ip address prefix-list BLOCKOUTBOUNDBGP1
route-map Nexus permit 20
match ip address prefix-list BLOCKOUTBOUNDBGP2
set as-path prepend 300 300 300
ATLAS
router bgp 300
neighbor 172.17.0.1 remote-as 300
neighbor y.y.y.1 remote-as 200
neighbor y.y.y.1 ebgp-multihop 2
neighbor y.y.y.1 update-source FastEthernet0/0/0
address-family ipv4
  neighbor 172.17.0.1 activate
  neighbor y.y.y.1 activate
  neighbor y.y.y.1 soft-reconfiguration inbound
  neighbor y.y.y.1 prefix-list BLOCKINBOUNDBGP in
  neighbor y.y.y.1 route-map Atlas out
  no auto-summary
  no synchronization
exit-address-family
ip prefix-list BLOCKOUTBOUNDBGP1 seq 10 permit 61.2.2.0/24
ip prefix-list BLOCKOUTBOUNDBGP2 seq 10 permit 61.1.1.0/24
Hey Val,
Apology for late reply.
What/Where is Norwest in the diagram??
Ameya
Hi Val,
I believe you meant to say How will Nexus router know about the public pools of Atlas, please confirm.
This will happen via IBGP neighborship between Atlas and Nexus.
Ameya
Peter Valdes
Level 3
Level 3
Sorry you are correct. I was referring to Nexus router.
So iBGP will populate ISP1 of Atlas network?
Thanks again for your help. Appreciate your prompt replies.
Hi Val,
Yes you are right and Its vice-versa.
Atlas will populate 61.1 pool and Nexus will populate 61.2 pools from IBGPs.
Ameya
Hi Amera,
Should i setup a static route of 0.0.0.0/0 via iBGP next hop IP with a metric of say 25?
Or will iBGP send the local default route I received from ISP1 (B*   0.0.0.0/0 [20/0] via ISP1) across the point to point aswell?
Hi Val,
No need to add default route, IBGP will take care of it.
Please rate helpful posts.
Ameya
Hi Ameya,
Thanks for your last reply.
Here are the results.
Before Atlas failover to Nexus Internet:
ATL-GW1#sh ip bgp
BGP table version is 16, local router ID is 61.2.2.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
* i0.0.0.0          X.X.X.1 (ISP1)          0    100   1000 10223 i
*>                  Y.Y.Y.1 (ISP2)           0          2000 24093 i
*>i61.1.1.0/24   172.17.0.1               0    100   1000 i
*> 61.2.2.0/24   0.0.0.0                  0         32768 i
During Atlas failover to Nexus Internet
ATL-GW1#sh ip bgp
BGP table version is 6, local router ID is 61.2.2.1
r>i0.0.0.0          X.X.X.1 (ISP1)          0    100   1000 10223 i
ip route 0.0.0.0 0.0.0.0 172.17.0.1 100 name DEFAULT-ROUTE-NEXUS
I had to add the above default static routers for this to work because when I did a "show ip route", the routing table didnt have a default rout via 172.17.0.1 point to point link to Nexus. Strange as I thought the nexus default route would be in Atlas routing table via iBGP but it didnt have it.
Is there  any other way of removing the static default route above and rely on iBGP to populate the routing table?
If i remove the above static default route, my connection out to the Internet fails.
Also, just incase I have place a weight on BGP for both neighbours. eBGP neighbour at 2000 and iBGP neighbour at 1000. This config is applied on both Atlas an Nexus.
Try to add the bellow command on both iBGP peers and rest the begp session and try it after removing the static
Default route
neighbor 172.17.0.x next-hop-self
Hope this help
Thanks for your prompt reply. I'll add the config mentioned and test it. Will let you know how it goes.
Thanks again
Hi Val,
As marvan suggested,inorder to reach ATALS routes to the internet u wl hv to set 172.17.0.X as the next-hope.without next-hope self command NEXUS ebgp g/w wil replicate to ATALS .
Thanks everyone for your help.
All is working as expected.
Cheers
