Error from router cisco 3600
Hello,I have router cisco cat: 3600, it had a problem in the time the reset print to screen,
Thank you for your help, I undersand that it had a problem with motherboard,
art Init is disabled. IOMEM set to: 15
Using iomem percentage: 15
Error, bridge 1 not DEC21152, returned 0xFFFFFFFF
Error, bridge 3 not DEC21152, returned 0xFFFFFFFF
Error, bridge 5 not DEC21152, returned 0xFFFFFFFF
%ERR-1-GT64120 (PCI-1): Fatal error, PCI Master abort
GT=0xB4000000, cause=0x00000400, mask=0x00D01D00, real_cause=0x00000400
bus_err_high=0x00000000, bus_err_low=0x31000000, addr_decode_err=0x00000470
*** Watch Dog Timeout ***
PC = 0x605acdfc, SP = 0x6181c070
C3660 processor with 65536 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
program load complete, entry point: 0x80008000, size: 0x864e20
Self decompressing the image : ######################################################################################### [OK]
best resgard.
Ivan Krimmel
Level 7
Level 7
Hi Jorge,
did you see this once during the reboot, or it somehow has an operational impact?
I'd try to reseat the modules currently installed, perhaps would boot the chassis up without any modules at all and see if the message will go away.
Speaking to hardware problem this might be a broken memory or a malfunctioning backplane. In both cases you would need to go for a TAC Service Request. We can't ship you the RMA off this thread ;)
HTH,
Ivan.
P.S. in case you have not read this yet - http://www.cisco.com/en/US/customer/products/hw/routers/ps274/products_tech_note09186a0080094aef.shtml
Message was edited by: Ivan Krimmel
Hi Ivan Krimmel
     Thank your answer,
     this problem ocurred during the work, this router cut the comunication and the team tenichian verifiy the router from hypeterminal..
best resgad
