BGP Configuration Issue
gregwoodson
I had a BGP configuration that was based on interface address instead of loopback. This gave me errors on the router, but routes were passed. I have changed this configuration over to the loopback addresses, and although the bgp neighbors show to be active, none of the routes are being shared.
ROUTER A
interface Loopback0
ip address 10.255.0.0 255.255.255.255
no ip redirects
no ip unreachables
router bgp xxxxx
bgp log-neighbor-changes
neighbor 10.255.0.7 remote-as xxxxx
neighbor 10.255.0.7 update-source Multilink1
neighbor XX.XX.XX.XX remote-as 65512
neighbor XX.XX.XX.XX update-source Multilink12
address-family ipv4
redistribute static
redistribute ospf XXXXX match internal external 1 external 2
neighbor 10.255.0.7 activate
neighbor XX.XX.XX.XX activate
no auto-summary
no synchronization
network 10.255.0.0 mask 255.255.255.255
exit-address-family
address-family vpnv4
neighbor 10.255.0.7 send-community both
neighbor XX.XX.XX.XX send-community both
exit-address-family
address-family ipv4 vrf CustomerA
redistribute connected
redistribute static
redistribute ospf 65507 vrf CustomerA match internal external 1 external 2
default-information originate
no synchronization
exit-address-family
address-family ipv4 vrf CustomerB
redistribute static
redistribute ospf 65512 vrf CustomerB match internal external 1 external 2
neighbor 10.105.255.10 remote-as 65512
neighbor 10.105.255.10 activate
no synchronization
aggregate-address 10.105.0.0 255.255.0.0 summary-only
exit-address-family
ROUTER B
interface Loopback0
ip address 10.255.0.7 255.255.255.255
no clns route-cache
router bgp XXXXX
neighbor 10.255.0.0 remote-as XXXXX
neighbor 10.255.0.0 update-source Multilink1
address-family ipv4
neighbor 10.255.0.0 activate
no auto-summary
no synchronization
network 10.255.0.7 mask 255.255.255.255
exit-address-family
neighbor 10.255.0.0 send-community both
exit-address-family
redistribute static
no auto-summary
no synchronization
exit-address-family
The other BGP peering is working just fine. The 10.255.0.0 to 10.255.0.7 peering is not working. I have verified pings from one router to the other to confirm connectivity.
Greg
Hi Greg,
Great to hear the peering works now!
Can you post "show bgp vpnv4 unicast" or the VRF specific portion from both routers? Can you also post "show bgp vpnv4 unicast all X.X.X.X" for a specific prefix under question from both routers? The config does not look too bad ;-) But on the other hand it is not the complete VRF related config, which makes it hard to judge what is going wrong.
Regards, Martin
6 Replies 6
mheusing
"ACTIVE" means, that no TCP session is established. This can either be IP connectivity related (you checked that - hopefully with an extended ping specifying the Loopback as source) or BGP related. The latter can be because of wrong source IP, wrong AS and the like.
In your case make sure the update-source refers to the Loopback interfaces.
Router A
router bgp xxxxx
neighbor 10.255.0.7 update-source Loopback0
Router B
router bgp XXXXX
neighbor 10.255.0.0 update-source Loopback0
Hope this helps!
Regards, Martin
Thanks Martin!
There is one problem we are now having though-
ROUTER A
router bgp XXXXX
neighbor 10.255.0.7 remote-as XXXXX
address-family ipv4
redistribute static
no auto-summary
no synchronization
exit-address-family
exit-address-family
redistribute static
no synchronization
exit-address-family
redistribute static
no synchronization
exit-address-family
ip route 10.255.0.7 255.255.255.255 Multilink1 10.0.0.2
ROUTER B
router bgp XXXXX
address-family ipv4
no auto-summary
no synchronization
network 10.0.0.2 mask 255.255.255.252
exit-address-family
exit-address-family
redistribute static
no auto-summary
no synchronization
exit-address-family
ip route 0.0.0.0 0.0.0.0 10.0.0.1
OK- the BGP Peering is now working. The only remaining problem is: in Router B, we are receiving routes from the other BGP peers with their gateways as the destination. We are not seeing 10.0.0.1 from within the CustomerB vrf. Thus, we are not able to get past Router A and to the other BGP peers. What is missing to be able to see the interface so that we can get to the next hop?
Greg
One more question- why do the cisco configuration guides show each VRF as having their own loopback?
Greg
Hi Greg,
Not every MPLS VPN configuration guide does have a Loopback per VRF, because in many cases there is no need for it. For some features like OSPF sham link, a Loopback is needed in the VRF. Which documents are you refering to?
Hope this helps! Please rate all posts.
Regards, Martin
Hi Greg,
Regards, Martin
Martin,
Thanks for your help! I got the whole thing figured out late last nite. There were vrf BGP tweaks all over the place that were needed. I appreciate the help!
Greg
