router 2811
jose.jimenez
What's the command to remove IOS from a router? I need to return a unit back to Cisco, but need to remove config, ios.
JORGE RODRIGUEZ
Level 10
Level 10
Jose,
this is the command to erase the config, not the IOS. You may want to leave the IOS in the router.
router>config t
router#erase nvram
then
router#reload
this process should clear your startup config.
Jorge Rodriguez
Thank you! Worked out great...
