BGP configuration
monsun1423
hi,
we have router with two ISP each 45 mbps link(fast ether) terminating to it. what I want a full network redudancy(in case one down) and best route conveges and load balancing using both links.
pls suggest a configuration
isp A: 192.168.3.1
Isp B:172.16.14.2
lan
192.168.0.2
Hi Monsun,
Since you have one router(I am assuming its Cisco) multihomed to 2 ISP's you can use WEIGHT,  asp-path prepend  attibutes to achieve this so that you get a primary/backup kinda of failover redundancy.
Please see the config below
===ISP A  (Primary)
router bgp 300
neighbor 192.168.3.1 remote-as 100
neighbor 192.168.3.1 weight 40000
===ISP B  (backup)
router bgp 300
neighbor 172.16.14.2 remote-as 200
neighbor 172.16.14.2 route-map AS_PATH_PREPEND out
match ip address 101
set as-path 300 300 3000
access-list 101 permit ip 192.168.0.2 255.255.255.0 any
HTH,
Please rate if useful
See the below link will help you with two different ISP's with multihomed setup.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
Please rate the helpfull posts.
Naidu.
kishor,
I want to use both ISP link as load-balancing , also in case one down other link can take up without any delay. I want to do tgat on single router itself.
also best path must be choosen from both with minimun latency
Hi Monsun.,
This is what I think you can do
You can use the maximum-paths 2 under bgp process on your router
since you are connected to 2 different ISP's.
BGP maximum-paths 2 works if the following criteria for selecting the BGP best path match:
weight, local preference, AS path length, origin code, MED.
if all these parameters are a match BGP can use two paths
However, there is a workaround .
bgp bestpath as-path multipath-relax    This commands helps you to load balance between 2 diff AS's outbound.
If you want inbound load balancing as well then , split your local LAN into two subnets and advertise with each one with different AS_PATH prepending
to the ISP's
HTH,
Pleas rate if helpful
