QoS on 3560
nilesh_sawant
hi
I have WS-C3560G-48PS on which internet link is connected & from same switch internet is extended to end users, VPN gateway & for my we server. I want to restrict the  internet bandwidth on portwise
In short
Internet connectivity  is on Gig0/1 of 5mbps
End users firewall connected on Gig0/2  <-- Want to restrict the in & out bw to 2mb
VPN gateway connected on Gig0/3        <-- Want to restrict the in & out bw to 1mb
Webserver connected on Gig0/4        <-- Want to restrict the in & out bw to 2mb
Can anyone advice what configuration i need to do on the switch?
Switch IOS is c3560-ipbase-mz.122-35.SE5.bin, if reqire i can upgrade the IOS.
Thanks in advance.
Dennis Mink
Nilesh,
assuming you are going to configure this from the CLI,
there are 3 steps to the process of configuring QoS:
1-Classification  (using the class-map statement)
2-ACTION   (using policy map statements)
3-Enable on interface  (using the service policy statement, on the WAN interface in this case)
1-You have identified 4 types of traffic (coming from 4 different ports), so you will need to create 4 separate Access lists that can classify this traffic.
At this stage you should already have you named ACL's with the names below  (INTERNET, WEB_SRVR etc)
class-map match-all INTERNET
match access-group name INTERNET
class-map match-all END_USERS_FIREWALL
match access-group name  END_USERS_FIREWALL
class-map match-all VPN_GW
match access-group name VPN_GW
class-map match-all WEB_SRVR
match access-group name WEB_SRVR
2 Create the policy map that defines what to do with the traffic defined in the previous step.
policy-map WAN_OUT
   class INTERNET
   bandwidth 5000
   class END_USERS_FIREWALL
   bandwidth 2000
   classVPN_GW
   bandwidth 1000
   class END_WEB_SRVR
   bandwidth 2000
3-
interface GigabitEthernet0/0
description provider Connection
bandwidth 1024000
ip address 10.200.200.4 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip flow egress
load-interval 30
duplex full
speed 100
service-policy output WAN_OUT<---------------------------------
please let me know if it is helpfull and rate if it is
Please remember to rate useful posts, by clicking on the stars below.
