BGP default originate
lcaruso
Level 6
Level 6
This question is about a multiple site, ISP managed, BGP network where the CE routers are not managed by the provider.
At the head end site, a BGP default originate command is used on the CE router to have all other CE routers/sites send their Internet traffic to the head end. Now this company is expanding and wants to route Internet traffic to a different location for selected new locations. Is there a way to effect this without getting the provider to change their routing?
I'll provide a simple example to be clear: Site A is the head end. Sites B and C send all of their Internet traffic across an ISP managed BGP backbone to Site A because Site A's CE employs the default orginate command. Site D comes along and now it is desired to send Site D's Internet traffic to Site B and leave all else the same.
How can this be accomplished--can default originate be selective on a per site basis?
Thanks.
Ruben Cocheno
the provider needs to be envolved on that, unless if it is temporary you can create a GRE tunnel for that purpose.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
