BGP default route to none BGP router
MonkeyBear007
This is for lab  i want to use BGP
My problem you usually default route by neighbor command
I'm not running on my router so i need to inject default to home router all the BGP route but not the sure of the command
8 Replies 8
there is no way
either you run BGP in home router or run IGP
the easy way is use default route in your home router point to ISP
MHM
network 0.0.0.0
ip route 0.0.0.0 0.0.0.0 172.32.1.1
Following didn't work when i try it
what command you recommend?
Where you add this defualt route ??
MHM
Usually route-map or default is at neighbor but i don't have one facing the home router
address-family ipv4
network 0.0.0.0
i used to have " ip route 0.0.0.0 0.0.0.0 null0" but i took it out.
Should i do no auto summ?
Hello
Run an IGP (eigrp) between home rtr and DC1/2,and DC1/2 links
from home rtr advertise a summary via both links towards DC1/2
int x/x
description to dc1
ip summary-address eigrp x  0.0.0.0/0
int x/y
description to dc2
Kind Regards
Paul
Thank you
Friend
You are so welcome
MHM
