04-12-2022 09:25 AM
Hi Everyone.
I have Cisco Router 3945 that has been configure with 2 neighbor BGP. and sometimes BGP is flapping only few second and its say error no supported AFI/SAFI.
Could you let me what could be a reason for it?
Apr 2 19:14:55.147 GMT: %BGP-3-NOTIFICATION: sent to neighbor 172.16.254.29 4/0 (hold time expired) 0 bytes
Apr 2 19:14:55.147 GMT: %BGP-5-NBR_RESET: Neighbor 172.16.254.29 reset (BGP Notification sent)
Apr 2 19:14:55.147 GMT: %BGP-5-ADJCHANGE: neighbor 172.16.254.29 Down BGP Notification sent
Apr 2 19:14:55.147 GMT: %BGP_SESSION-5-ADJCHANGE: neighbor 172.16.254.29 IPv4 Unicast topology base removed from session BGP Notification sent
Apr 2 19:15:08.717 GMT: %BGP-5-NBR_RESET: Neighbor 172.16.254.29 passive reset (Peer closed the session)
Apr 2 19:15:08.717 GMT: %BGP-5-ADJCHANGE: neighbor 172.16.254.29 passive Down AFI/SAFI not supported
Apr 2 19:15:08.749 GMT: %BGP-5-ADJCHANGE: neighbor 172.16.254.29 Up
Apr 12 14:57:14.419 GMT: %BGP-3-NOTIFICATION: sent to neighbor 172.16.254.33 4/0 (hold time expired) 0 bytes
Apr 12 14:57:14.419 GMT: %BGP-5-NBR_RESET: Neighbor 172.16.254.33 reset (BGP Notification sent)
Apr 12 14:57:14.419 GMT: %BGP-5-ADJCHANGE: neighbor 172.16.254.33 Down BGP Notification sent
Apr 12 14:57:14.419 GMT: %BGP_SESSION-5-ADJCHANGE: neighbor 172.16.254.33 IPv4 Unicast topology base removed from session BGP Notification sent
Apr 12 14:57:41.956 GMT: %BGP-5-NBR_RESET: Neighbor 172.16.254.33 passive reset (Peer closed the session)
Apr 12 14:57:41.958 GMT: %BGP-5-ADJCHANGE: neighbor 172.16.254.33 passive Down AFI/SAFI not supported
Apr 12 14:57:42.158 GMT: %BGP-5-ADJCHANGE: neighbor 172.16.254.33 Up
Both .29 and .33 are IBGP neighbor
thanks
04-12-2022 10:08 AM
Does this neighbors has IPV6 enable?
Can you run "debug bgp all" ?
04-12-2022 10:27 AM
04-12-2022 10:42 AM
Yeah, but what about the other side?
04-12-2022 11:04 AM
other side router is actually third party router, i do not have access on there, i just wanna make sure on my side router first
04-12-2022 11:23 AM
This messages indicates that the router (yours or others) is trying to negociate aditional capabilities and one side does not understand. This can be multiple protocol like IPv6 and/or muticast protocol.
04-12-2022 10:48 AM - edited 04-12-2022 10:50 AM
Hello
Looks like possible mismatch capabilities, try the following:
router bgp xxx
neighbor 172.16.254.29 dont−capability−negotiate
neighbor 172.16.254.33 dont−capability−negotiate
04-12-2022 11:03 AM
Hi Paul
is there any alternate command ? unfortunate in cisco 3945 there is no such that command available
04-12-2022 07:19 PM
Hello
It is a hidden command, append it manually and it should be accepted.
05-17-2023 03:42 AM
Hello
I am presently facing this issue while processing iBGP between cisco and juniper device.
The "dont−capability−negotiate" doesn't solve the issue. VPNV4 prefixes are not exchanged with the juniper peer.
From the cisco' side i have
Route refresh: advertised and received(new)
Four-octets ASN Capability: advertised and received
Address family IPv4 Unicast: advertised and received
Address family VPNv4 Unicast: advertised
Is there a way to solve this interoperability issue?
05-17-2023 06:05 AM
Hi @paul mebale ,
You have already posted this question in another conversation. I will try to help in this other conversation.
