08-10-2021 05:04 AM
I have multiple BGP sessions for SDDC based on NSX-T, they are connected to Cisco ASA 5555-X. We have 4 BGP connections for redundancy as suggested by the NSX-T design team, but as I can see that traffic is coming from one interface & leaving from the other. I have been asked by the NSX-T team to check if ECMP is enabled on the ASA, but I couldn't find any resource that specifies any command to check the status of ECMP or enable it on the ASA.
Is it supposed to be enabled by default, or do I have to enable it somehow?
08-10-2021 05:09 AM
Hello @ammartalal ,
under router bgp
you need
maximum-paths 4
as the default for BGP is 1.
However, being an ASA there are some restrictions on how ECMP can work. It is a firewall first then a router so unless all the 4 next-hops are reachabled via the same named interface I'm afraid you cannot achieve ECMP on all 4 eBGP sessions.
Hope to help
Giuseppe
08-10-2021 05:54 AM
Dear Giuseppe,
What do you mean by "the same named interface"? Is it the same physical interface, or same logical interface?
Thank you for your reply.
08-10-2021 09:01 AM
Hello @ammartalal ,
if you are using ASA classic operating system the name is that given under the L3 interface that can be a routed L3 interface or a logical interface.
How are configured the interfaces to the eBGP neighbors ? they are in a port-channel ? They are members of the same bridge group ?
They are indipendent each with its own IP address ?
Hope to help
Giuseppe
08-10-2021 10:07 PM
Dear Giuseppe,
The interfaces are in the same port-channel, sub-interfaces. Each interface with its own /30 IP address range. They are not on the same bridge group.
The interfaces configuration on my side is as below:
interface port-channel1.422 security-level 100 ip address xxx.xxx.2.25 255.255.255.252 interface Port-channel1.423 security-level 100 ip address xxx.xxx.2.29 255.255.255.252 interface Port-channel1.424 security-level 100 ip address xxx.xxx.2.33 255.255.255.252 interface Port-channel1.425 security-level 100 ip address xxx.xxx.2.37 255.255.255.252
The interfaces configuration on the NSX-T side is as below:
interface port-channel1.422 ip address xxx.xxx.2.26 255.255.255.252 interface Port-channel1.423 ip address xxx.xxx.2.30 255.255.255.252 interface Port-channel1.424 ip address xxx.xxx.2.34 255.255.255.252 interface Port-channel1.425 ip address xxx.xxx.2.38 255.255.255.252
If I have to use a single interface (port-channel1.422 for example), how can I add multiple IP addresses to the same interface?
08-10-2021 11:10 PM
Hello @ammartalal ,
verify what happens when you modfiy the maximum-paths under router bgp.
if you see 4 paths installed and used you are fine.
You have to verify with people managing the NSX if they can use a single wider subnet for their side.
But again this is needed only if ECMP does not work with different interfaces on ASA.
Hope to help
Giuseppe
08-12-2021 12:47 AM
Hello @Giuseppe Larosa
The maximum paths are already set at 4, and I can see the below output when I execute "show bgp 172.28.10.10", where 172.28.10.0/24 is a subnet advertised on all 4 BGP peers.
BGP routing table entry for 172.28.10.0/24, version 386 Paths: (4 available, best #4, table default) Multipath: eBGP Not advertised to any peer 65001 172.26.2.26 from 172.26.2.26 (172.26.2.26) Origin incomplete, metric 0, localpref 100, valid, external, multipath 65001 172.26.2.34 from 172.26.2.34 (172.26.2.26) Origin incomplete, metric 0, localpref 100, valid, external, multipath 65001 172.26.2.38 from 172.26.2.38 (172.26.2.38) Origin incomplete, metric 0, localpref 100, valid, external, multipath 65001 172.26.2.30 from 172.26.2.30 (172.26.2.38) Origin incomplete, metric 0, localpref 100, valid, external, multipath, best
Do the above prove ECMP is working or not?
The people managing NSX have no issue with a wider subnet, but is it possible to have multiple IP addresses at the same interface on ASA?
08-13-2021 12:05 AM
Hello @ammartalal ,
For a standard router it would be enough as the multipath attribute is there to demonstrate tha maximum-paths 4 is effective.
Being an ASA a stateful firewall there might be some limitations on how ECMP can work.
Can you post a show version so that we can see what version of ASA o.s is running on the device ?
Hope to help
Giuseppe
08-14-2021 10:50 PM
Cisco Adaptive Security Appliance Software Version 9.13(1) SSP Operating System Version 2.7(1.107) Device Manager Version 7.14(1) Compiled on Mon 23-Sep-19 09:38 PDT by builders System image file is "disk0:/asa9-13-1-smp-k8.bin" Config file at boot was "startup-config" ASA up 34 days 18 hours Hardware: ASA5555, 16384 MB RAM, CPU Lynnfield 2800 MHz, 1 CPU (8 cores) ASA: 8792 MB RAM, 1 CPU (2 cores) Internal ATA Compact Flash, 8192MB BIOS Flash MX25L6445E @ 0xffbb0000, 8192KB Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1 ) Boot microcode : CNPx-MC-BOOT-2.00 SSL/IKE microcode : CNPx-MC-SSL-SB-PLUS-0005 IPSec microcode : CNPx-MC-IPSEC-MAIN-0026 Number of accelerators: 1 Baseboard Management Controller (revision 0x1) Firmware Version: 2.4 0: Int: Internal-Data0/0 : address is f80b.cb28.17df, irq 11 1: Ext: GigabitEthernet0/0 : address is f80b.cb28.17e4, irq 5 2: Ext: GigabitEthernet0/1 : address is f80b.cb28.17e0, irq 5 3: Ext: GigabitEthernet0/2 : address is f80b.cb28.17e5, irq 10 4: Ext: GigabitEthernet0/3 : address is f80b.cb28.17e1, irq 10 5: Ext: GigabitEthernet0/4 : address is f80b.cb28.17e6, irq 5 6: Ext: GigabitEthernet0/5 : address is f80b.cb28.17e2, irq 5 7: Ext: GigabitEthernet0/6 : address is f80b.cb28.17e7, irq 10 8: Ext: GigabitEthernet0/7 : address is f80b.cb28.17e3, irq 10 9: Int: Internal-Data0/1 : address is 0000.0001.0002, irq 0 10: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 0 11: Int: Internal-Data0/2 : address is 0000.0001.0003, irq 0 12: Ext: Management0/0 : address is f80b.cb28.17df, irq 0 13: Int: Internal-Data0/3 : address is 0000.0100.0001, irq 0 Licensed features for this platform: Maximum Physical Interfaces : Unlimited perpetual Maximum VLANs : 500 perpetual Inside Hosts : Unlimited perpetual Failover : Active/Active perpetual Encryption-DES : Enabled perpetual Encryption-3DES-AES : Enabled perpetual Security Contexts : 2 perpetual Carrier : Disabled perpetual AnyConnect Premium Peers : 5000 perpetual AnyConnect Essentials : Disabled perpetual Other VPN Peers : 5000 perpetual Total VPN Peers : 5000 perpetual AnyConnect for Mobile : Enabled perpetual AnyConnect for Cisco VPN Phone : Enabled perpetual Advanced Endpoint Assessment : Enabled perpetual Shared License : Disabled perpetual Total TLS Proxy Sessions : 2 perpetual Botnet Traffic Filter : Disabled perpetual IPS Module : Disabled perpetual Cluster : Enabled perpetual Cluster Members : 2 perpetual This platform has an ASA5555 VPN Premium license. Serial Number: FCH2103J3MP Running Permanent Activation Key: 0xa008d671 0xacd17a69 0x3dc3dd68 0xc4101c70 0x0b04e7ba Configuration register is 0x1 Image type : Release Key version : A Configuration last modified by xxxx at 09:57:25.950 AST Thu Aug 12 2021
This is the output of the show version.
Best regards,
