Bgp-Eigrp-Bgp redistribution question
marcusbrutus
Level 4
Level 4
Hi Experts,
Just wish to ask if there is an option to retain the as-path information in eigrp when i redistribute from bgp to eigrp then to bgp?
I recall coming across something similar to this before but I can't seem to remember it.
Thanks in advance.
Gustavo Coutinho
Community Member
Hello friend.
No, you can't retain the AS-PATH when redistributing prefixes from BGP to EIGRP.
What you CAN do though, is to add the AS-PATH you want when redistributing it BACK to BGP.
You can do something like this:
1 - Add a TAG when redistributing the BGP prefixes into EIGRP
route-map SET_TAG permit 10
 set tag 100
router eigrp 1
redistribute bgp 100 metric 1 1 1 1 1 route-map SET_TAG
2 - transform the TAG into an AS_PATH, when redistributing it BACK to BGP.
route-map set-as-path-from-tag
set as-path tag
router bgp 100
redistribute eigrp 1 route-map set-as-path-from-tag
Got it ?
I hope this helps you !
cheers
Gustavo Coutinho
Community Member
Hello friend.
 set tag 100
router eigrp 1
set as-path tag
router bgp 100
Got it ?
cheers
