BGP failover routing
sridhar ch
I need some help in BGP routing. is it possible to publish the same network in two sites which are connected using MPLS cloud? I have 10 locations, all are connected using MPLS. I have a dedicted link between 2 sites (site A and B), so that if site A MPLS link is down for some reason then the traffic shud come on dedicted link and then take MPLS link of site B.  what would be the impact if i publish the same network that site A is publishing in BGP? FYi, bot the sites has different AS numbers.
Sridhar
Craig_Baum_2
Are both sites to the same ISP? or different as they'd advertise your address blocks and so will only advertise the ones they own.
If different ISPs make sure you block non local IP networks to prevent becoming a transit.
Marwan ALshawi
the questions are valid by the above post
however generally speaking it is for sure doable
however you need to make sure that you put the right BGP polices to influence the path selection in both direction inbound and outbound in both situation where one line is down or both are up
you can use AS prepending to effect the inbound traffic from other sites
if yo are using one AS between A and B then you can use local preference in the inbound direction to effect the outbound traffic from those sites
hope this help
if helpful rate
To stop each AS becoming a transit AS:
ip as-path access-list 1 permit ^$
router bgp xxxx
network (isp x.x.x.x) filter-list 1 out
FYI -You could use aspath prending to effect both outbound/inbound traffic but as stated above the preferred way would to go with prepending for inbound traffic and local-preferance for outbound .
res
Paul
Kind Regards
Paul
avi_krivorot
Although it's possible, you can't guarantee that all traffic will come to site A. Even with AS prepending. I was told that some ISPs may load balance traffic on a per packet basis to different paths. I would recommend you test this for a few weeks before implementing in production.
Avi
