BGP filter only ip
rdrigues
I would like you to help me with the question below:
I have BGP below with AS 65400;
neighbor 10.117.6.3
remote-as 65400
local-as 65401
address-family ipv4 unicast
I want the partner AS to know only one
/24
network using
route-map
How can I make a
route-map
allowing only this network?
2 Accepted Solutions
M02@rt37
Hello @rdrigues,
First, create a Prefix List matching the
/24
to announce (outbound) :
ip prefix-list ALLOW_ONLY_24 permit 10.0.0.0/24
Then, create a
Route Map
references this Prefix List :
route-map ALLOW_ONLY_24_NETWORK permit 10
match ip address prefix-list ALLOW_ONLY_24
Finally, apply this
Route Map
to your neihgbor:
router bgp 65400
neighbor 10.117.6.3
route-map ALLOW_ONLY_24_NETWORK out
Note: you could use ACL instead of Prefix List, and in the same way call this ACL under your
Route Map
Best regards
Blue_Bird
Router(config)# ip prefix-list list-1 permit x.x.x.x/24
Router(config)# route-map map-1 permit 10
Router(config-route-map)# match ip addess prefix-list list-1
Router(config-route-map)#end
Router(config)# router bgp 65400
Router(config-router)# adddress-family ipv4 unicast
Router(config-router-af)#neighbor 10.117.6.x route-map map-1 out
Best regards
******* If This Helps, Please Rate *******
M02@rt37
Hello @rdrigues,
/24
Then, create a
Route Map
Finally, apply this
Route Map
to your neihgbor:
router bgp 65400
neighbor 10.117.6.3
Route Map
Best regards
Blue_Bird
Best regards
rdrigues
wonderful, I'll do some tests
