BGP flapping between routers
palani2010
BGP Flapping between routers not issue seen between router. How to troubleshoot further.
5 Replies 5
the first think you must looking for is
MTU mismatch between two peer
MHM
Hello
Can you elaborate on your issue and topology please?
Do you mean the bgp peering is flapping or routes?
How are the rtrs connected - directly or via a l2 handoff switch/firewall?
What type of peering is this -  ebgp/ibgp?
Are you using any igp as a underlay transit?
Kind Regards
Paul
Both routers are directly connected.
Types of BGP - EBGP
Hello
So how are they peering - physical or logical interfaces (loopbacks)
Do  see any interface errors
Are you using default static routes
Is reachabilty to the peering addresses okay
Kind Regards
Paul
