Bookmark
Subscribe
707
BGP - General question
johnhsnow
When I remove a BGP route from the running config on my corebox - I still see the route when I use show ip bgp neighbors x.x.x.x advertised-routes. I know I can clear the routing table by using clear ip bgp * soft [in|out] but does anyone know how long it will take before the table deletes the route from its table?
the default minimum time between advertisement runs is 30 seconds, so it would take about 30 seconds for the route to disappear from the BGP routing table.
HTH,
GP
Clear ip bgp* simply causes the TCP session between neighbors to be reset and since BGP is a fast converged protocol the cache is cleared and routes will appear roughly 30-40 seconds
