Filter specific BPDU
jasonchang
Dear All :
I need to filter specific BPDU(possible trunk port or access port ),allow remaining BPDU come into interface , the system device that i used is Cisco7600 Router
any suggestion to do it ?
thanks
rais.ahmad
You can turn off Spanning Tree for selected VLANs. You can also use any of other features STP provides:
http://www.cisco.com/en/US/products/hw/switches/ps5213/products_configuration_guide_chapter09186a00801ce017.html#1046220
Hope this helps.
