BGP how long takes to install best routes
Anatoly Fanrus
help me pls, how long takes bgp to install new best routes(FULL VIEW) to routing table if i reset my primary neighbor. I have second neighor with AS-PATH PREPEND. I need to know will be break in routing or not.
Lei Tian
Default BGP advertisement interval is 30 sec for eBGP neighbor. You can do clear IP BGP soft to force the update.
HTH,
Lei Tian
