4006 ios upgrade
WEERAKOO69BA
Hi i have a  WS-C4006
switch.It has
IOSCAT
{System Bootstrap Version: 5.4(1)}.I need to upgrade CATIOS in to ciscoIOS.Can anybody give me the steps???
thx
9 Replies 9
Giuseppe Larosa
Hello Weerakoo69ba,
I think you can only upgrade to a newer catos image.
for example one of my c4006 has been upgraded to be able to support linecards WS-4548
switch (enable) sh ver
WS-C4006 Software, Version NmpSW: 8.4(11)GLX
Copyright (c) 1995-2006 by Cisco Systems, Inc.
NMP S/W compiled on Apr 27 2006, 12:44:02
GSP S/W compiled on Apr 27 2006, 11:47:52
Hardware Version: 3.2  Model: WS-C4006  Serial #: FOX06170K9U
Mod Port Model              Serial #              Versions
1   2    WS-X4013           JAE06210259          Hw : 3.2
                                                 Gsp: 8.4(11.0)
                                                 Nmp: 8.4(11)GLX
2   48   WS-X4548-GB-RJ45   JAE1228OLNK          Hw : 2.5
3   48   WS-X4148-RJ45V     JAE062104XU          Hw : 1.6
4   48   WS-X4148-RJ        JAE061906RL          Hw : 3.0
5   48   WS-X4548-GB-RJ45   JAE1229P23C          Hw : 2.5
6   48   WS-X4448-GB-RJ45   JAB06190CMB          Hw : 1.0
we have installed the 8.4(11)GLX
there is a conversion procedure from CatOS to IOS  for C6500 but not for C4006 as far as I know
Hope to help
Giuseppe
thanks a lot for your prompt reply.
Guiseppe's right.  WS-X4013 will only run at CatOS.  You need the WS-X4013+ to run Cisco IOS.
Hello Weerakoo69ba,
check with sh module what kind of supervisor you have as noted by Leo.
Leo: the sh module was from my device we don't know the original poster what supervisor has in his chassis
Hope to help
Giuseppe
Hi Giuseppe,
I'm suspecting it is a 4013.
Dear giuslar  and Leo,
Supervisor engine is WS-X4013            .That means it is not possible to upgrade to IOS???
Engg_VLAN3> (enable) sh ver
WS-C4006 Software, Version NmpSW: 6.3(9)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Sep 23 2002, 18:48:29
GSP S/W compiled on Sep 23 2002, 16:23:28
Hardware Version: 1.3  Model: WS-C4006  Serial #: FOX04453664
1   2    WS-X4013   JAB050209Y1          Hw : 1.3
                                         Gsp: 6.3(9.0)
                                         Nmp: 6.3(9)
2   6    WS-X4306-GB JAE110878C3          Hw : 4.3
3   34   WS-X4232-GB-RJ JAB042001U4          Hw : 2.3
4   36   WS-X4232-RJ-XX JAE091284F2          Hw : 1.7
5   36   WS-X4232-RJ-XX JAB035106U4          Hw : 1.7
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1       65536K  34319K  31217K  16384K   8499K   7885K  480K  235K  245K
Uptime is 599 days, 9 hours, 1 minute
Engg_VLAN3> (enable) sh module
Mod Slot Ports Module-Type               Model               Sub Status
1   1    2     1000BaseX Supervisor      WS-X4013            no  ok
2   2    6     1000BaseX Ethernet        WS-X4306-GB         no  ok
3   3    34    10/100/1000 Ethernet      WS-X4232-GB-RJ      no  ok
4   4    36    10/100/1000 Ethernet      WS-X4232-RJ-XX      yes ok
5   5    36    10/100/1000 Ethernet      WS-X4232-RJ-XX      yes ok
Mod Module-Name          Serial-Num
1                        JAB050209Y1
2                        JAE110878C3
3                        JAB042001U4
4                        JAE091284F2
5                        JAB035106U4
Mod MAC-Address(es)                        Hw     Fw         Sw
1   00-04-c1-ed-82-00 to 00-04-c1-ed-85-ff 1.3    5.4(1)     6.3(9)
2   00-0e-38-e2-63-02 to 00-0e-38-e2-63-07 4.3
3   00-01-42-82-b7-9a to 00-01-42-82-b7-bb 2.3
4   00-12-43-5e-a6-a0 to 00-12-43-5e-a6-cf 1.7
5   00-01-42-20-5c-b0 to 00-01-42-20-5c-df 1.7
Mod Ports Sub-Type                  Sub-Model       Sub-Serial           Sub-Hw
4   33-36 100BaseFX Ethernet        WS-U4504-FX-MT  JAE09065G9L          1.6
5   33-36 100BaseFX Ethernet        WS-U4504-FX-MT  JAE0821JRP5          1.1
yes you can  only upgrade to last CatOS as we did in our device. this specific supervisor model supports only catos
Hope to help
Giuseppe
Do you know the way of changing the password in CATOS base 4006(same switch) switch???What are the commands
thx
vinit shah
HI Team,
even i am running the IOS "cat4000-k9.8-4-11-GLX.bin" on the device WS-c4506.......
I am trying to initiate a command "set port broadcast  " but unable to execute the same......
can anybody suggest any alternate command ?
"sh version"
WS-C4506 Software, Version NmpSW: 8.4(11)GLX
NMP S/W compiled on Apr 27 2006, 12:46:44
System Bootstrap Version: 6.1(5)
Hardware Version: 5.1  Model: WS-C4506  Serial #: FOX07190054
1   2    WS-X4013           JAE07190RLS          Hw : 5.1
                                                 Gsp: 8.4(11.0)
                                                 Nmp: 8.4(11)GLX
2   48   WS-X4148-RJ        JAE07220WV3          Hw : 3.1
3   48   WS-X4148-RJ        JAE07220XW7          Hw : 3.1
4   48   WS-X4148-RJ        JAE07220XS9          Hw : 3.1
5   48   WS-X4148-RJ        JAE07220XQ3          Hw : 3.1
       DRAM                    FLASH                   NVRAM
1       65536K  41377K  24159K  16384K   5930K  10454K  480K  399K   81K
Uptime is 80 days, 19 hours, 30 minutes
"sh module"
****************** show module ******************
2   2    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
3   3    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
4   4    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
5   5    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
1                        JAE07190RLS
2                        JAE07220WV3
3                        JAE07220XW7
4                        JAE07220XS9
5                        JAE07220XQ3
1   00-0d-28-22-c1-40 to 00-0d-28-22-c1-7f 5.1    6.1(5)     8.4(11)GLX
2   00-0c-30-7e-b7-90 to 00-0c-30-7e-b7-bf 3.1
3   00-0c-ce-ef-15-f0 to 00-0c-ce-ef-16-1f 3.1
4   00-0c-ce-ef-18-90 to 00-0c-ce-ef-18-bf 3.1
5   00-0c-30-7e-b5-50 to 00-0c-30-7e-b5-7f 3.1
