03-27-2025 10:25 PM
Team,
This is my core configuration where all traffic is routed through TTSL (14.96.31.X). I want to change the traffic route to use Airtel as the primary path (182.76.237.X)."
03-28-2025 12:41 AM
Hello @saahiprahi ,
your router is running IOS XR because I see route policies configured. To make one eBGP neighbor preferred over another one you can increase the local preference value that you set in the policy applied inbound to the peer.
You can use set local-preference 3000 in the policy applied inbound to Airtel
Hope to help
Giuseppe
04-07-2025 02:31 AM
Thank you Giuseppe will configure and check the traffic
03-28-2025 01:13 AM
