BGP - How to influence partial network on outgoing update
guibarati
Level 4
Level 4
Does anyone know if it's possible to influence only a portion of the networks updates been sent over eBGP connection?
If I am advertising the network 100.1.1.0/24, and I have this network directly connected on one interface, the router is connected to two ISPs (with different AS's). Can I influence the updates to say the host 100.1.1.20 has better path through ISP A and everything else ISP B?
16 Replies 16
If I announce a more specific and prepend the AS a few times on the AS-PATH wouldn't it make the Internet see this ISP as "less preferred"?
Yes. Advertising a more specfic with prepends should do the trick.
