Filter connected interface from EIGRP
dchew
How do you filter a connected interface from EIGRP even though it is defined on the network command?
Example:
interface vlan 100
ip address 10.1.1.1 255.255.255.0
router eigrp 1
passive-interface default
network 10.0.0.0 0.255.255.255
How do I filter 10.1.1.0 255.255.255.0 from participating in EIGRP 1?  Network command can not be modified.
THanks,
mvsheik123
Level 7
Level 7
You mean not to advertise 10.1.1.0/24 via eigrp? I guess you can use prefix list to deny 10.1.1.0/24 and allow all others in the the eigrp process. Correct me if I got your question wrong.
Thx
MS
Yes.  Is this possible?  Will it impact any other routes on other interfaces?
Access-list 20 deny any
Router eigrp 1
Distribute-list 20 in vlan 100
It should work...
ip prefix-list EIGRP_OUT seq 5 deny 10.1.1.0/24
ip prefix-list EIGRP_OUT seq 10 permit 0.0.0.0/0 le 32
router eigrp
distribute-list prefix EIGRP_OUT out
hth
MS
