BGP inject-map/advertise-map and VRFs
lbjwusatx
I have a requirement to advertise more specific BGP ranges from learned routes for multi-home load balancing improvements and was intending to use an advertise-map or inject-map to perform this. The prefixes are originated elsewhere in the network and we advertise them at our borders
However, this seems to be unavailable if your neighbours are declared inside a VRF.
For example, bgp inject-map cannot be declared inside the VRF address-family and the advertise-map command cannot be specified after the neighbour if you are in the address-family ipv4 vrf abc.
Can anyone shed any light on if this is by design and if by design why and then what else I might do short of originating the lower prefixes from elsewhere.
I'm using 15.0(1)M on 7200-NPE-G1.
lbjwusatx
Here's an example.
router(config-router-af)#neighbor 1.2.3.4 ?
  activate                 Enable the Address Family for this Neighbor
  advertisement-interval   Minimum interval between sending BGP routing updates
  allowas-in               Accept as-path with my AS present in it
router(config-router)#neighbor 1.2.3.4 ?
  advertise-map            specify route-map for conditional advertisement
This seems to indicate that VRF aware conditional advertisment only became available in 15.3(3)M?
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/15-s/irg-15-s-book/irg-vrf-conditional-adv.html
Was it available in 12.x?
