BGP, Ip Public, Ip Private With ASR1001-x
RDjack
Sorry if my Language is bad.
I have a problem setting in cisco asr 1001-x.
I have 2 ip BGP Global & Domestic,
Example:
- BGP Global = 172.16.10.182 / 30
- BGP Domestic = 172.16.10.186 / 30
- Ip Public = 192.16.10.1 / 24
- Ip Private = 192.168.11.1 / 24
Scheme:
Internet
    [] (BGP)
  ASR
    [] [] [] Bandwidth Management (192.16.10.19 / 24)
    []         ip private 192.168.11.1 / 24
c3850
Until ASR ping to gateway BGP 172.16.10.181 & 172.16.10.185 succes, ping to google.com succes, ping to private ip succes.
If From client private ip, device c3850, device Management Bandwidth ping ASR 172.16.10.182; 172.16.10.186; 192.16.10.1 succes no problem.
But if From client private ip, device c3850, device Management Banding ping neighbor BGP 172.16.10.181; 172.16.10.185; ping google.com no succes.
are there any configuration errors or something missing with my configuration?
i have 2 ip BGP for global & domestic connection, and my ip public / 24. I think if 2 ip BGP I seting as nat outside,
for ip public should ip nat inside or ip nat outside
Please corrections
My configuration:
interface Loopback0
 no ip address
interface TenGigabitEthernet0/0/0
 no ip address
 shutdown
interface TenGigabitEthernet0/0/1
 no ip address
 shutdown
interface GigabitEthernet0/0/0
 description BGP Global
 ip address 172.16.10.186 255.255.255.252
 ip nat outside
 negotiation auto
 ip virtual-reassembly
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/0/1.10
 description PUBLIC
 encapsulation dot1Q 10
 ip address 192.16.10.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/0/2
 description BGP Domestik
 ip address 172.16.10.182 255.255.255.252
 ip nat outside
 negotiation auto
router ospf 1
 network 192.16.10.0 0.0.0.255 area 9
 network 172.16.10.180 0.0.0.3 area 9
 network 172.16.10.184 0.0.0.3 area 9
 network 192.168.11.0 0.0.0.255 area 9
router bgp 54321
 bgp log-neighbor-changes
 network 192.16.10.0
 network 172.16.10.180 mask 255.255.255.252
 network 172.16.10.184 mask 255.255.255.252
 neighbor 172.16.10.181 remote-as 4432
 neighbor 172.16.10.185 remote-as 4432
ip nat inside source list 1 interface GigabitEthernet0/0/1.10 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip tftp source-interface GigabitEthernet0
ip route profile
ip route 192.16.10.0 255.255.255.0 192.16.10.19
ip route 192.16.11.0 255.255.255.0 192.16.10.19
ip access-list extended Port_Block
 deny   tcp any any eq msrpc
 deny   tcp any any eq 136
 deny   tcp any any eq 137
 deny   tcp any any eq 138
 deny   tcp any any eq 139
 deny   udp any any eq 135
 deny   udp any any eq 136
 deny   udp any any eq netbios-ns
 deny   udp any any eq netbios-dgm
 deny   udp any any eq netbios-ss
 deny   udp any any eq 445
 deny   tcp any any eq 445
 deny   tcp any any eq 593
 deny   tcp any any eq 4444
 deny   tcp any any eq 4000
 deny   tcp any any eq 995
 deny   tcp any any eq 996
 deny   tcp any any eq 997
 deny   tcp any any eq 998
 deny   tcp any any eq 999
 deny   tcp any any eq 8998
 deny   tcp any any eq 2745
 deny   tcp any any eq 4751
 deny   tcp any any eq 1434
access-list 1 permit 192.16.10.0 0.0.0.254
ipv6 access-list preauth_v6
 permit udp any any eq domain
 permit tcp any any eq domain
 permit icmp any any nd-ns
 permit icmp any any nd-na
 permit icmp any any router-solicitation
 permit icmp any any router-advertisement
 permit icmp any any redirect
 permit udp any eq 547 any eq 546
 permit udp any eq 546 any eq 547
 deny ipv6 any any
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
your NAT statement specifies the wrong outgoing interface:
GigabitEthernet0/0/1.10 is the NAT inside interface. You need to specify a NAT outside interface:
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
or
ip nat inside source list 1 interface GigabitEthernet0/0/2 overload
whether just enough one
ip nat inside source list 1 interface GigabitEthernet0 / 0/0 overload
or
ip nat inside source list 1 interface GigabitEthernet0 / 0/2 overload
because of my ISP given IP BGP Global, IP BGP Domestic, & Public IP.
I want when the browsing that is detected is my public ip 192.16.10.19
sorry for the misunderstanding, I cannot figure out what you are trying to accomplish. Post in your native language (French/Spanish/whatever), we can translate...
sorry for my ambiguous language.
from isp A, i get:
- ip BGP Global = 172.16.10.180 / 30
- ip BGP Domestic = 172.16.10.184 / 30
- ip Public (AS Number) id Nic = 192.16.10.0 / 24
my office will use ASR 1001 for the main Router
scheme:
== Internet (ISP) ==
       []     (Global BGP + domestic BGP + AS Number)
       []      - ip BGP Global = 172.16.10.181 / 30
       []         (neighbor 172.16.10.181 remote-as 4432)
       []      - ip BGP Domestic = 172.16.10.185 / 30
       []      - router bgp 54321
== ASR == - ip BGP Global = 172.16.10.182 / 30
       []         - ip BGP Domestic = 172.16.10.186 / 30
       []         - ip Public (AS Number) id Nic = 192.16.10.1 / 24
       [] [] []  == Bandwidth Management == (192.16.10.19 / 24)
== c3850 == (ip private 192.168.11.2 / 24)
- ASR ping to gateway BGP 172.16.10.181 & 172.16.10.185 succes, ping to google.com succes, ping to private ip 192.168.11.2 succes.
- From client private ip or device c3850 or device Management Bandwidth ping ASR 172.16.10.182 or 172.16.10.186 or 192.16.10.1 succes no problem.
- But if From client private ip or device c3850 or device Management Bandwidth ping 172.16.10.181 or 172.16.10.185 or ping google.com no succes.
Please corrections
My configuration:
interface Loopback0
 no ip address
 no ip address
 shutdown
 no ip address
 shutdown
 ip nat outside
 negotiation auto
 no ip address
 negotiation auto
 description PUBLIC
 ip nat inside
 ip nat outside
 negotiation auto
router ospf 1
router bgp 54321
 network 192.16.10.0
ip http server
ip route profile
 deny ipv6 any any
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
