BGP is not redis EIGRP vrf CE routes
mohAmed khAdr
Pls. take as look at this config and tell me if I am missing something.
I can't get BGP to redis EI routes bet PEs.
BGP nei is established, so is OS & EI..yet I can't ping bet CEs ( I dont see any external routes on any CE)
Thx.
mohAmed
Robert Taylor
So ... can you even ping between CE devices for the connected networks?  Try using "redistribute connected" in the vrf address family so that you can ping CE wan ip to CE wan ip.
Can you ping between the PEs VRF interfaces?  "ping vrf CE_ME 68.139.xxx.xxx source serial1/0"?
Ill look at your config and see if anything else looks out of whack, but finding out exactly which IPs you are trying to ping between would be helpful.
Hey Rob,
Thx for your respond...I figure it out: I have to add "redis ei" under os.....and now I can ping across between all CEs.
Still routing looks out of whack....I 'll keep at it..till I dig it out!!!!!.
I am trying to config QoS between the 3 CEs<< for data>>... I will keep you posted.
Thx again.
mohAmed
