BGP lab help
Andy White
Level 7
Level 7
I'm just testing my knowledge (or lack of) with this lab I'm doing, can anyone hint as to why I can't ping 4.4.4.4 from R1 eventhough it is valid and best?
R1
R1#sh run | s router
router bgp 100
no synchronization
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
neighbor 10.1.1.5 remote-as 500
neighbor 172.12.123.2 remote-as 100
neighbor 172.12.123.3 remote-as 300
no auto-summary
R1#
R1#sh ip bgp
BGP table version is 7, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 1.1.1.1/32       0.0.0.0                     0              32768   i
*>i2.2.2.2/32       172.12.123.2             0    100      0        i
*> 3.3.3.3/32       172.12.123.3             0               0      300 i
* i                      172.12.123.2             0    100      0       300 i
*  4.4.4.4/32       172.12.123.3                              0       300 400 i
*>i                     172.12.123.2             0    100      0       400 i
*> 5.5.5.5/32       10.1.1.5                   0               0       500 i
R1#
R2
R2#sh run | s router
router bgp 100
no synchronization
network 2.2.2.2 mask 255.255.255.255
neighbor 172.12.123.1 remote-as 100
neighbor 172.12.123.1 next-hop-self
neighbor 172.12.234.3 remote-as 300
neighbor 172.12.234.4 remote-as 400
no auto-summary
R2#
R2#sh ip bgp
BGP table version is 5, local router ID is 2.2.2.2
*>i1.1.1.1/32       172.12.123.1             0    100         0            i
*> 2.2.2.2/32       0.0.0.0                     0                32768        i
* i3.3.3.3/32       172.12.123.3             0    100          0         300 i
*                        172.12.234.4                                 0          400 300 i
*>                      172.12.234.3             0                  0          300 i
*  4.4.4.4/32       172.12.234.3                                 0          300 400 i
*>                     172.12.234.4             0                   0          400 i
* i5.5.5.5/32       10.1.1.5                    0    100         0           500 i
R2#
R3
R3#sh run | s router
router bgp 300
no synchronization
network 3.3.3.3 mask 255.255.255.255
neighbor 172.12.34.4 remote-as 400
neighbor 172.12.234.2 remote-as 100
no auto-summary
R3#
R3#sh ip bgp
BGP table version is 6, local router ID is 3.3.3.3
*  1.1.1.1/32       172.12.234.2                                    0       400 100 i
*                        172.12.34.4                                     0       400 100 i
*                        172.12.234.2                                   0        100 i
*>                      172.12.123.1             0                    0         100 i
*  2.2.2.2/32       172.12.123.1                                   0        100 i
*                        172.12.234.2                                   0        400 100 i
*>                      172.12.234.2             0                    0        100 i
*> 3.3.3.3/32       0.0.0.0                    0                     32768      i
*  4.4.4.4/32       172.12.123.1                                   0        100 400 i
*                       172.12.234.4                                    0       100 400 i
*                       172.12.234.4             0                     0       400 i
*>                      172.12.34.4              0                     0       400 i
*> 5.5.5.5/32       172.12.123.1                                  0        100 500 i
R3#
R4
R4#sh run | s router
router bgp 400
no synchronization
network 4.4.4.4 mask 255.255.255.255
neighbor 172.12.34.3 remote-as 300
no auto-summary
R4#
R4#sh ip bgp
BGP table version is 6, local router ID is 4.4.4.4
*  1.1.1.1/32       172.12.234.3                                   0      300 100 i
*                        172.12.34.3                                    0      300 100 i
*>                      172.12.234.2                                  0      100 i
*  2.2.2.2/32       172.12.234.3                                  0      300 100 i
*  3.3.3.3/32       172.12.234.3                                  0      100 300 i
*                        172.12.234.3             0                   0      300 i
*>                      172.12.34.3               0                   0      300 i
*> 4.4.4.4/32       0.0.0.0                     0                   32768 i
*  5.5.5.5/32       172.12.234.3                                  0       300 100 500 i
*>                      172.12.34.3                                   0       300 100 500 i
R4#
5 Replies 5
How do you test it? Just with a "ping 4.4.4.4"?
I would assume that the ping reaches R4 (you can test that with "debug ip icmp" on R4), but if you don't specify the source of your ping as 1.1.1.1, then R4 can't answer the ping as R4 doesn't know how to reach 172.12.123.1
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Doh, ping 4.4.4.4 source 1.1.1.1 worked.
To get R4 to ping 172.12.123.1 is it best to add a routing protocol over the top?
This is R4:
     1.0.0.0/32 is subnetted, 1 subnets
B       1.1.1.1 [20/0] via 172.12.234.2, 01:41:15
     2.0.0.0/32 is subnetted, 1 subnets
B       2.2.2.2 [20/0] via 172.12.234.2, 01:41:15
     3.0.0.0/32 is subnetted, 1 subnets
B       3.3.3.3 [20/0] via 172.12.34.3, 01:41:15
     4.0.0.0/32 is subnetted, 1 subnets
C       4.4.4.4 is directly connected, Loopback0
     5.0.0.0/32 is subnetted, 1 subnets
B       5.5.5.5 [20/0] via 172.12.34.3, 01:41:15
     172.12.0.0/16 is variably subnetted, 3 subnets, 2 masks
C       172.12.234.0/24 is directly connected, FastEthernet0/0
C       172.12.34.3/32 is directly connected, Serial0/0
C       172.12.34.0/24 is directly connected, Serial0/0
R4#
and R1
C       1.1.1.1 is directly connected, Loopback0
B       2.2.2.2 [200/0] via 172.12.123.2, 01:42:28
B       3.3.3.3 [20/0] via 172.12.123.3, 01:42:22
B       4.4.4.4 [200/0] via 172.12.123.2, 00:05:16
B       5.5.5.5 [20/0] via 10.1.1.5, 01:42:30
     172.12.0.0/24 is subnetted, 1 subnets
C       172.12.123.0 is directly connected, Serial0/0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, FastEthernet0/0
R1#
R4 has to learn it through BGP as you don't want an IGP between your different AS. Tell your routers to also anounce the transfer-links.
I've not heard of transfer links, would you mind explaining this a little more and how I can configure?
transfer links means the links between your routers but usually you only advertsie your end host subnets not the links between your routers and to test it you specify the source address in your ping.
Alain
