10-01-2013 12:16 PM - edited 03-04-2019 09:12 PM
Good Day,
I am trying to resolve an issue using IP SLA and tracking. I have a router that has multiple routes. I have 2 that are over wireless connections and one that is a last resort for Cellular. I have a issue where both wireless routes are up and i want the route with the better throughput/bandwidth at that time to be the primary route. here is a portion on the configuration that i am working with. any advice would be appreciated..
ip route 0.0.0.0 0.0.0.0 10.10.10.1 track 1 10
ip route 0.0.0.0 0.0.0.0 10.10.10.2 track 2 20
ip route 0.0.0.0 0.0.0.0 10.10.10.3 50
ip sla 1
icmp-echo 10.10.10.1 source-ip 10.10.10.20
timeout 500
threshold 2
frequency 15
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 10.10.10.2 source-ip 10.10.10.20
timeout 500
threshold 2
frequency 15
ip sla schedule 2 life forever start-time now
track 1 ip sla 1 reachability
delay down 30 up 45
track 2 ip sla 2 reachability
delay down 30 up 45
10-01-2013 01:37 PM
IP SLA cannot help you with routing traffic based on link performance (Bandwidth/delay/throughput). It can only help you with reachability.
You need PfR to intelligently route based on performance -
http://www.cisco.com/en/US/products/ps8787/products_ios_protocol_option_home.html
10-01-2013 11:12 PM
HI Dennis,
As Vishesh told u that:
This is absolutely correct form my point of view.
IP SLA is only used to to tack the link. If one link is dwon then another can come up.
Here is the example.
R1(config)# ip sla 1
R1(config)#icmp-echo 2.2.2.2 source-interface FastEthernet0/0
R1(config)# timeout 1000
R1(config)#threshold 2
R1(config)# frequency 3
R1(config)# ip sla schedule 1 life forever start-time now
R1(config)# track 1 ip sla 1 reachability
R1(config)#ip route 0.0.0.0 0.0.0.0 2.2.2.2 track 1
R1(config)# ip route 0.0.0.0 0.0.0.0 3.3.3.3 10
You can aslo see the status of tracking by:
R1# show track
Track 1
IP SLA 1 reachability
Reachability is Down
1 change, last change 00:03:19
Latest operation return code: Unknown
Hope it Helps
10-03-2013 06:36 AM
Thank you for the responses. I will look at Performance routing.
