BGP Lapping
jennytong
Hi Tech friends,
I have struggled this question for a long time. Can you guys help me with that?
Problem 1: the ebgp connection between R2 and R7 is up and down a lot
Problem 2: I cannot use R1 to learn all the route of R7 and R8
Really appreciate your help~
q.PNGHere is my configuration:
R1:
version 15.2
hostname CE1
boot-start-marker
boot-end-marker
vrf definition acme
rd 1:1100
route-target export 1:1100
route-target import 1:1100
address-family ipv4
exit-address-family
no aaa new-model
ip vrf mgmt
rd 1:1000
route-target export 1:1000
route-target import 1:1000
ip cef
no ipv6 cef
redundancy
interface Loopback1
ip vrf forwarding mgmt
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Ethernet1/0
vrf forwarding acme
ip address 172.16.12.1 255.255.255.0
duplex half
interface Ethernet1/1
no ip address
shutdown
duplex half
interface Ethernet1/2
no ip address
shutdown
duplex half
interface Ethernet1/3
no ip address
shutdown
duplex half
interface Ethernet1/4
no ip address
shutdown
duplex half
interface Ethernet1/5
no ip address
shutdown
duplex half
interface Ethernet1/6
no ip address
shutdown
duplex half
interface Ethernet1/7
no ip address
shutdown
duplex half
router bgp 27
bgp always-compare-med
bgp log-neighbor-changes
timers bgp 10 30
address-family ipv4 vrf acme
redistribute connected
neighbor 172.16.12.2 remote-as 27
neighbor 172.16.12.2 activate
neighbor 172.16.12.2 send-community both
neighbor 172.16.12.2 soft-reconfiguration inbound
exit-address-family
address-family ipv4 vrf mgmt
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
R2:
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service counters max age 5
no service dhcp
hostname R2
boot-start-marker
boot-end-marker
vrf definition acme
rd 1:1100
address-family ipv4
exit-address-family
no aaa new-model
ip vrf mgmt
rd 1:1000
ip cef
no ipv6 cef
mpls label range 16 1048575
mpls label protocol ldp
redundancy
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Loopback1
no ip address
shutdown
duplex half
description connection to R7 the first
ip address 10.23.0.2 255.255.255.0
duplex full
mpls bgp forwarding
mpls ip
description connection to R7 the second
ip address 10.24.0.2 255.255.255.0
duplex full
mpls bgp forwarding
mpls ip
description connection to R1
vrf forwarding acme
ip address 172.16.12.2 255.255.255.0
duplex half
description connection to R3
vrf forwarding acme
ip address 156.16.12.2 255.255.255.0
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
router eigrp 27
network 2.2.2.2 0.0.0.0
network 10.23.0.0 0.0.255.255
network 10.24.0.0 0.0.255.255
passive-interface default
no passive-interface Ethernet1/0
no passive-interface Ethernet1/1
router bgp 27
bgp router-id 2.2.2.2
neighbor 7.7.7.7 remote-as 28
neighbor 7.7.7.7 ebgp-multihop 2
neighbor 7.7.7.7 update-source Loopback0
address-family ipv4
neighbor 7.7.7.7 activate
neighbor 7.7.7.7 send-community both
neighbor 7.7.7.7 soft-reconfiguration inbound
neighbor 7.7.7.7 send-label
exit-address-family
address-family vpnv4
exit-address-family
neighbor PEER1 peer-group
neighbor PEER1 remote-as 26
neighbor PEER1 ebgp-multihop 2
neighbor PEER1 send-community both
neighbor PEER1 next-hop-self
neighbor PEER1 allowas-in
neighbor PEER1 soft-reconfiguration inbound
neighbor PEER2 peer-group
neighbor PEER2 remote-as 27
neighbor PEER2 send-community both
neighbor PEER2 next-hop-self
neighbor PEER2 soft-reconfiguration inbound
neighbor 156.16.12.1 peer-group PEER1
neighbor 156.16.12.1 activate
neighbor 172.16.12.1 peer-group PEER2
neighbor 172.16.12.1 activate
exit-address-family
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
R7:
version 15.2
no service pad
no service dhcp
hostname R7
boot-start-marker
boot-end-marker
vrf definition acme
rd 110:110
route-target export 110:110
route-target import 110:110
address-family ipv4
exit-address-family
no aaa new-model
ip vrf mgmt
rd 1:1000
ip cef
no ipv6 cef
redundancy
interface Loopback0
description global loopback
ip address 7.7.7.7 255.255.255.255
interface Loopback1
description management loopback
no ip address
shutdown
duplex half
ip address 10.23.0.1 255.255.255.0
duplex full
mpls bgp forwarding
mpls ip
ip address 10.24.0.1 255.255.255.0
duplex full
mpls bgp forwarding
mpls ip
vrf forwarding acme
ip address 192.168.78.7 255.255.255.0
duplex half
vrf forwarding acme
ip address 111.1.1.1 255.255.255.0
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
router eigrp 27
network 7.7.7.7 0.0.0.0
router ospf 2
network 111.0.0.0 0.255.255.255 area 0
router bgp 28
bgp router-id 7.7.7.7
neighbor 2.2.2.2 remote-as 27
neighbor 2.2.2.2 ebgp-multihop 2
neighbor 2.2.2.2 update-source Loopback0
address-family ipv4
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community both
neighbor 2.2.2.2 soft-reconfiguration inbound
neighbor 2.2.2.2 send-label
exit-address-family
exit-address-family
neighbor PEER3 peer-group
neighbor PEER3 remote-as 28
neighbor PEER3 send-community both
neighbor PEER3 next-hop-self
neighbor PEER3 soft-reconfiguration inbound
neighbor 192.168.78.8 peer-group PEER3
neighbor 192.168.78.8 activate
exit-address-family
exit-address-family
no ip http server
ip route 0.0.0.0 0.0.0.0 7.7.7.77
ip route 7.7.7.7 255.255.255.255 2.2.2.2
ip route 7.7.7.7 255.255.255.255 10.23.0.2
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
R8:
version 15.2
hostname R8
boot-start-marker
boot-end-marker
vrf definition acme
rd 1:1100
address-family ipv4
exit-address-family
no aaa new-model
ip vrf mgmt
rd 1:1000
ip cef
no ipv6 cef
redundancy
interface Loopback0
no ip address
interface Loopback1
ip address 8.8.8.8 255.255.255.255
no ip address
shutdown
duplex half
vrf forwarding acme
ip address 192.168.78.8 255.255.255.0
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
router bgp 28
timers bgp 10 30
neighbor 192.168.78.7 remote-as 28
neighbor 192.168.78.7 activate
neighbor 192.168.78.7 send-community both
neighbor 192.168.78.7 soft-reconfiguration inbound
exit-address-family
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
tellis002
I'm not sure overall what you are asking, but I think you are asking due to the ebgp session between router 2 and router 7 going up and down, you want to fail over to the link between router 7 <--> router 3.  Taking a glance at it, you are not redistributing any BGP routes into OSPF on Router 7.  So even if everything else is correct, R3 will never receive and/or pass on routes that R7 is aware of via BGP.
