BGP load sharing MID attribute
R Manjunatha
Level 3
Level 3
I have two hub routers, R1 and R2. R1 is the primary router for the office, and R2 is the backup. R1 is connected to 8000 offices through Flex VPN. My requirement is to share the load between the two hub routers, R1 and R2. Currently, I am using the BGP attribute MED to route all the traffic primarily to R1
R1
Rrouter 65020
bgp router id 10.10.10.10
bgp listing range 192.168.20.0/24 peer-group office
bgp listen limit 10000
address-family ipv4 vrf office
neighbor office peer group
neighbor office remote-as 65010
Neighbour office route-map office_BGP_OUT out
route-map office_BGP_OUT permit 10
set metric 100
R2
Rrouter 65020
bgp router id 20.20.20.20
set metric 110
Hub1#show run
Hub1#show running-config
Building configuration...
Current configuration : 3287 bytes
! Last configuration change at 20:30:36 UTC Thu Jun 20 2024
version 15.2
hostname Hub1
boot-start-marker
boot-end-marker
enable password hub1
aaa new-model
aaa authorization network default local
aaa session-id common
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
username hub1 password 0 hub1
ip tcp synwait-time 5
crypto ikev2 authorization policy default
pool IKEv2
route set interface
crypto ikev2 proposal prop
encryption des
integrity md5
group 5
crypto ikev2 policy poli
proposal prop
crypto ikev2 keyring key
peer ANY
address 0.0.0.0 0.0.0.0
pre-shared-key cisco
crypto ikev2 profile prof
match identity remote address 0.0.0.0
authentication remote pre-share
authentication local pre-share
keyring local key
aaa authorization group psk list default default
virtual-template 1
crypto ipsec transform-set trans esp-des esp-md5-hmac
mode tunnel
crypto ipsec profile prof
set transform-set trans
set ikev2-profile prof
interface FastEthernet0/0
ip address 100.0.0.1 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/0
ip address 10.0.0.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet3/1
ip address 20.0.0.1 255.255.255.0
speed auto
duplex auto
interface Virtual-Template1 type tunnel
ip address 5.0.0.1 255.255.255.0
ip nhrp network-id 5
ip nhrp redirect
tunnel source FastEthernet0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile prof
router bgp 100
bgp log-neighbor-changes
bgp listen range 5.0.0.4/32 peer-group PEERS-B
bgp listen range 5.0.0.3/32 peer-group PEERS-A
network 10.0.0.0 mask 255.255.255.0
network 20.0.0.0 mask 255.255.255.0
neighbor PEERS-A peer-group
neighbor PEERS-A remote-as 100
neighbor PEERS-A route-reflector-client
neighbor PEERS-A next-hop-self
neighbor PEERS-A route-map A out
neighbor PEERS-B peer-group
neighbor PEERS-B remote-as 100
neighbor PEERS-B route-reflector-client
neighbor PEERS-B next-hop-self
neighbor PEERS-B route-map B out
ip local pool IKEv2 5.0.0.3 5.0.0.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 100.0.0.10
ip prefix-list 10.0.0.0 seq 5 permit 10.0.0.0/24
ip prefix-list 20.0.0.0 seq 5 permit 20.0.0.0/24
route-map A permit 10
match ip address prefix-list 10.0.0.0
set metric 100
route-map A permit 20
match ip address prefix-list 20.0.0.0
set metric 200
route-map B permit 10
set metric 200
route-map B permit 20
set metric 100
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Hub2#show ru
Hub2#show running-config
Current configuration : 3293 bytes
! Last configuration change at 20:30:46 UTC Thu Jun 20 2024
version 15.2
hostname Hub2
boot-start-marker
boot-end-marker
enable password Hub2
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
username Hub2 password 0 Hub2
pool IKEv2
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
virtual-template 1
mode tunnel
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 110.0.0.2 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 10.0.0.2 255.255.255.0
speed auto
duplex auto
ip address 20.0.0.2 255.255.255.0
speed auto
duplex auto
ip address 15.0.0.1 255.255.255.0
ip nhrp network-id 15
ip nhrp redirect
tunnel source FastEthernet1/1
router bgp 100
bgp listen range 15.0.0.4/32 peer-group PEERS-B
bgp listen range 15.0.0.3/32 peer-group PEERS-A
ip local pool IKEv2 15.0.0.3 15.0.0.254
no ip http server
ip route 0.0.0.0 0.0.0.0 110.0.0.10
set metric 200
set metric 100
set metric 100
set metric 200
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Spoke1#show run
Current configuration : 2505 bytes
version 15.2
hostname Spoke1
boot-start-marker
boot-end-marker
enable password spoke1
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
username spoke1 password 0 spoke1
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
mode tunnel
interface Tunnel0
ip address negotiated
ip nhrp shortcut
tunnel source FastEthernet1/0
tunnel destination 100.0.0.1
tunnel protection ipsec profile prof shared
interface Tunnel10
ip nhrp shortcut
tunnel destination 110.0.0.2
no ip address
shutdown
duplex full
ip address 120.0.0.100 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 100
neighbor 5.0.0.1 remote-as 100
neighbor 15.0.0.1 remote-as 100
no ip http server
ip route 0.0.0.0 0.0.0.0 120.0.0.10
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Spoke2#show run
Spoke2#show running-config
Current configuration : 2506 bytes
version 15.2
hostname Spoke2
boot-start-marker
boot-end-marker
enable password spoke2
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
username spoke2 password 0 spoke2
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
mode tunnel
interface Tunnel0
ip nhrp shortcut
tunnel source FastEthernet2/0
interface Tunnel10
ip nhrp shortcut
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 130.0.0.100 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 100
no ip http server
ip route 0.0.0.0 0.0.0.0 130.0.0.10
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
17 Replies 17
FlexVPN you meaning IKEv2 ?
MHM
R Manjunatha
Level 3
Level 3
yes
same config as you share in your post except
under the route-map match ip address prefix <>
this make Hub not use MED for all prefix but use MED only for specific prefix specify by match
MHM
R Manjunatha
Level 3
Level 3
Could you please provide the sample configuration of how to send traffic to 4000 office to R1 and 4000 office to R2
The load not 4000 to 4000
But it 8000 prefer R1 for specific prefix
Other 8000 perfer R2 for specific prefix
This how MED work.
I will draw topology to you today with some info.
MHM
R Manjunatha
Level 3
Level 3
Thank you for the update
could you please provide the sample configuration for this diagram?
sure tomorrow I will share lab
MHM
R Manjunatha
Level 3
Level 3
Thank you
Current configuration : 2124 bytes
! Last configuration change at 18:40:51 UTC Sun Jun 16 2024
version 15.2
hostname Hub1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Tunnel0
no ip redirects
tunnel source FastEthernet3/1
tunnel mode gre multipoint
tunnel key 5
standby 10 ip 10.0.0.10
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
standby 20 ip 20.0.0.20
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
router bgp 100
bgp listen range 5.0.0.0/8 peer-group PEERS
neighbor PEERS peer-group
neighbor PEERS remote-as 100
neighbor PEERS route-reflector-client
neighbor PEERS next-hop-self
neighbor PEERS route-map MEDHub1 out
no ip http server
route-map MEDHub1 permit 10
set metric 1000
route-map MEDHub1 permit 20
set metric 2000
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
! Last configuration change at 18:27:43 UTC Sun Jun 16 2024
version 15.2
hostname Hub2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
no ip redirects
tunnel key 5
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
router bgp 100
neighbor PEERS route-map MEDHub2 out
no ip http server
route-map MEDHub2 permit 10
set metric 2000
route-map MEDHub2 permit 20
set metric 1000
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
this load prefix 10.0.0.0 and 20.0.0.0 which connect to both Hub between Spoke1-8000
for load traffic between Spoke1-4000 Spoke4001-8000
we need to make to make two BGP peer-groups
one peer-group for half FlexVPN POOL and other for peer-group for other half
do you want other lab for this case
dont worry this lab take from me 30 min to run
MHM
I appreciate your valuable time in providing this information. Thank you.
do you want other lab for this case - Yes, please
Hub1#show run
version 15.2
hostname Hub1
boot-start-marker
boot-end-marker
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
pool IKEv2
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
virtual-template 1
mode tunnel
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
ip nhrp redirect
router bgp 100
no ip http server
set metric 100
set metric 200
set metric 200
set metric 100
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Hub2#show ru
version 15.2
hostname Hub2
boot-start-marker
boot-end-marker
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
pool IKEv2
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
virtual-template 1
mode tunnel
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
ip nhrp redirect
router bgp 100
no ip http server
set metric 200
set metric 100
set metric 100
set metric 200
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Spoke1#show run
version 15.2
hostname Spoke1
boot-start-marker
boot-end-marker
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
mode tunnel
interface Tunnel0
ip nhrp shortcut
interface Tunnel10
ip nhrp shortcut
no ip address
shutdown
duplex full
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Spoke2#show run
version 15.2
hostname Spoke2
boot-start-marker
boot-end-marker
aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
route set interface
encryption des
integrity md5
group 5
proposal prop
peer ANY
keyring local key
mode tunnel
interface Tunnel0
ip nhrp shortcut
interface Tunnel10
ip nhrp shortcut
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
Here we go the code of lab for you is shared
