BGP Local Pref, ASR router
Netmart
Level 3
Level 3
I was wondering, if there is a way to apply Local Preference [BGP] to a prefix which is not part of received BGP update.
Example:
Prefix received by BGP peer: 1.0.160.0/19
Instead of applying local preference to the whole subnet 1.0.160.0/19, I would like to apply local preference only to one host covered by this subnet. For example: 1.0.191.250/32
Since this host is not part of the prefixes provided via BGP updates by eBGP peer, local preference will never be applied for this IP 1.0.191.250/32.
Extract of BGP table:
 *>  1.0.160.0/19                    59.0.0.1      70080               0    1700  38000 777
Extract of BGP config:
access-list 1 permit host 1.0.191.250
route-map LocPref permit 10
match ip address 1
set local-preference 500
route-map LocPref  permit 20
router bgp 36000
bgp log-neighbor-changes
neighbor 59.0.0.1 route-map LocPref in
Please advise.
Thanks.
Harold Ritter
It is not possible to apply a policy to a route that does not exist. Could you please tell us more on what you are trying to achieve?
 Hi Harold,
Thank you for confirming.
