BGP MED Configuration Problem ?
Cormac Champion
I'm looking to add a MED to BGP of a secondary router in one site, but I'm having problems with it.
Router(config-router)#route-map MED permit 10
Router(config-router-map)#set weight 100
Router(config)#router bgp 65000
Router(config-router)#neighbor xx.xx.xx.xx route-map MED out
% "MED" used as BGP outbound route-map, set weight not supported
What have I done wrong here please ?
Deepak Kumar
Try with below command under the routemap
set metric 100
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13759-37.html
If you are trying to apply the weight than this value is only locally significant on the router and the information is not passed between neighbors
. I tried in the lab that It is only accepting the weight value with "IN" keyboard.
Deepa Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
set metric 100
Deepa Kumar
Deepak Kumar,
second option easy way
R1(config)# route-map MED
R1(config-route-map)# set metric 500
R2(config)# route-map MED
R2(config-route-map)# set metric 100
R1(config)# router bgp 1
R1(config-router)# neighbor x.x.x.x route-map MED out
R2(config)# router bgp 1
R2(config-router)# neighbor x.x.x.x route-map MED out
Wish all the best
