BGP MPLS PING ISSUE
Ammartehsein
CUSTOMER SITE NOT ABLE TO PING SITE 2, even routes are advertised properly via mpls bgp. I am pinging using loopback 10.10.10.1 as source from site 1.as you see below 10.10.10.0 network is received on other end
PE1 vrd routing table:
PE1#sh ip route vrf Riyadh-branch
Routing Table: Riyadh-branch
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 1.1.1.0/30 is directly connected, Ethernet1/0
L 1.1.1.2/32 is directly connected, Ethernet1/0
2.0.0.0/30 is subnetted, 1 subnets
B 2.2.2.0 [200/0] via 90.90.90.2, 01:14:58
10.0.0.0/24 is subnetted, 1 subnets
B 10.10.10.0 [20/0] via 1.1.1.1, 02:10:24
20.0.0.0/24 is subnetted, 1 subnets
B 20.20.20.0 [200/0] via 90.90.90.2, 01:14:58
PE-2 vrf routing table:
PE2#sh ip route vrf
PE2#sh ip route vrf Jeddah-branch
Routing Table: Jeddah-branch
1.0.0.0/30 is subnetted, 1 subnets
B 1.1.1.0 [200/0] via 70.70.70.1, 00:56:50
2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 2.2.2.0/30 is directly connected, Ethernet1/0
L 2.2.2.2/32 is directly connected, Ethernet1/0
B 10.10.10.0 [200/0] via 70.70.70.1, 00:56:50
B 20.20.20.0 [20/0] via 2.2.2.1, 00:56:50
Cust site-1 routing table:
Cust-1#sh ip route
L 1.1.1.1/32 is directly connected, Ethernet1/0
B 2.2.2.0 [20/0] via 1.1.1.2, 00:54:00
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 10.10.10.0/24 [200/0] via 0.0.0.0, 01:41:56, Null0
C 10.10.10.1/32 is directly connected, Loopback1
B 20.20.20.0 [20/0] via 1.1.1.2, 00:54:00
Cust site-2 routing table:
Cust-2#sh ip route
B 1.1.1.0 [20/0] via 2.2.2.2, 00:54:13
L 2.2.2.1/32 is directly connected, Ethernet1/0
B 10.10.10.0 [20/0] via 2.2.2.2, 00:54:13
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 20.20.20.0/24 [200/0] via 0.0.0.0, 01:44:39, Null0
C 20.20.20.1/32 is directly connected, Loopback1
Hi @Ammartehsein ,
You should use the PE loopback interface to establish the VPNv4 session between the two PEs. Also make sure the loopback interface is advertised by ospf.
This should solve the issue.
26 Replies 26
@Ammartehsein
 what do you have netween PE-1 and PE-2?
 PE-1 receive the 20.20.20.0 on the interface 90.90.90.2
PE-2 receive 10.10.10.0 on interface 70.70.70.1
Traceroute from Site 1 to Site 2 or vice-versa show what?
I have attached network diagram. It will clarify a bit more.
What protocol use between PE and CE
Under this protocol ""redistrubte connect""
MHM
BGP is used.
No problem
Under address family ipv4 vrf xxx
Redistrubte connect
MHM
added this cmd but still same not pinging
It is lab so mpls label assign and bgp advertise prefix need time.
For fast wr config
Trun off the lab and trun on again and check ping
MHM
No routes are already there The only issue is that it is not pinging
Mpls label this issue.
Only close and open lab and check' sure after wr
MHM
Harold Ritter
Hi @Ammartehsein ,
Could you please attach PE1 and PE2 configuration.
PE1#sh run
Building configuration...
Current configuration : 1984 bytes
! Last configuration change at 15:43:20 UTC Sat Nov 16 2024
upgrade fpd auto
version 15.3
hostname PE1
boot-start-marker
boot-end-marker
aqm-register-fnf
vrf definition Riyadh-branch
rd 200:1
route-target export 300:1
route-target import 300:1
address-family ipv4
exit-address-family
no aaa new-model
ip cef
no ipv6 cef
redundancy
interface Loopback20
ip address 30.30.30.30 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Ethernet1/0
vrf forwarding Riyadh-branch
ip address 1.1.1.2 255.255.255.252
duplex half
interface Ethernet1/1
ip address 70.70.70.1 255.255.255.252
ip ospf 1 area 0
duplex half
mpls ip
interface Ethernet1/2
no ip address
shutdown
duplex half
interface Ethernet1/3
no ip address
shutdown
duplex half
interface FastEthernet2/0
no ip address
shutdown
duplex half
router ospf 1
router bgp 200
bgp log-neighbor-changes
network 70.70.70.0 mask 255.255.255.252
neighbor 90.90.90.2 remote-as 200
neighbor 90.90.90.2 soft-reconfiguration inbound
address-family vpnv4
neighbor 90.90.90.2 activate
neighbor 90.90.90.2 send-community extended
exit-address-family
address-family ipv4 vrf Riyadh-branch
redistribute connected
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 soft-reconfiguration inbound
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
PE2#sh run
Current configuration : 1847 bytes
! Last configuration change at 15:22:10 UTC Sat Nov 16 2024
upgrade fpd auto
version 15.3
hostname PE2
boot-start-marker
boot-end-marker
aqm-register-fnf
vrf definition Jeddah-branch
rd 300:1
address-family ipv4
exit-address-family
no aaa new-model
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
duplex half
vrf forwarding Jeddah-branch
ip address 2.2.2.2 255.255.255.252
duplex half
ip address 90.90.90.2 255.255.255.252
ip ospf 1 area 0
duplex half
mpls ip
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
router ospf 1
router bgp 200
network 90.90.90.0 mask 255.255.255.252
neighbor 70.70.70.1 remote-as 200
neighbor 70.70.70.1 activate
neighbor 70.70.70.1 send-community extended
exit-address-family
address-family ipv4 vrf Jeddah-branch
neighbor 2.2.2.1 remote-as 100
neighbor 2.2.2.1 activate
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input all
end
Ohh ok
You use same as in same site
Then you need
Allowas-in or as override
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/112236-allowas-in-bgp-config-example.html
MHM
Still you need to close and then open lab for mpls label.
MHM
No, I already use this cmd and I am reacving routes. I closed lab and run again as you said but still same
