BGP Multi-homing on Cisco IOS XR , underlying LF and AS-PATH
Ibrahim Jamil
Level 6
Level 6
Hi Cisco Folks
Do you have config example from BGP Multi-homing on Cisco IOS XR , underlying  LF and AS-PATH
Philip D'Ath
What does LF mean?
What do you want to do with the AS-PATH?
Do you want to load balance, or do failover?
What is the IP address of your two neighbours, and what are their AS numbers, and what is your AS number?
Hi Philip
sorry mate . my mistake i must say LP not LF , its local preference
1. ASR-1 should announce 91.X.X.X/24 to ISP1 While ISP-2 will be the backup for 91.X.X.X/24
2. ASR-2 should announce 92.X.X.X/24 to ISP2 While ISP-1 will be the backup for 92.X.X.X/24
3. i am getting default route from both ISPs
attached topology
thanks
That is asking a lot!  How about I give you the majority of the solution and you tweak it from there.
Router 1:
router bgp <your asn>
  neighbor 172.16.1.x remote-as <ISP1 ASN>
  neighbor 172.16.1.x description ISP1
neighbour <internal neighbor ip> remote-as <your own ASN>
  address-family ipv4
network 91.x.x.x mask 255.255.255.0
network 92.x.x.x mask 255.255.255.0
network 172.16.1.x mask 255.255.255.252
neighbor 172.16.1.x activate
neighbor
172.16.1.x soft-reconfiguration inbound
neighbor 172.16.1.x prefix-list company-out
neighbor 172.16.1.x route-map isp1-in in
neighbor 172.16.1.x route-map isp1-out out
neighbour <internal neighbor ip> activate
neighbour <internal neighbor ip> soft-reconfiguration inbound
ip prefix-list company-out seq 5 permit 91.x.x.x/24
ip prefix-list company-out seq 10 permit 92.x.x.x/24
route-map isp1-in permit 10
set local-preference 110 <-- set (or don't set) whatever preference you want
set community local-AS
ip prefix isp1-backup-routes permit x.x.x.x/24
route-map isp1-out permit 10
match ip address prefix-list isp1-backup-routes
set as-path prepend <your ASN> <your ASN> <your ASN>
route-map isp1-out permit 20
Hi bro philip
i am okay with these IOS syntax , but bro , the above wont work with IOS XR
mate no route-map on XR but RPL
thanks a  lot bro
