BGP/Multihome using Private ASN
jeffbriones
Hi guys,
Do you have a sample config on these ?
Thanks.
jeff
mounir.mohamed
Level 7
Level 7
Dear,
Kindly use the below configurations example with some changes based on your routers interfaces and IP address.
IP CEF
ip classless
Interface Loopback 0
IP address 172.16.0.1 255.255.255.255
interface ATM1/0.1 point-to-point
desc ISP 1
ip address 172.16.1.1 255.255.255.252
pvc 1/1
enca aal5snap
Interface ATM2/0.1 point-to-point
desc ISP2
ip address 172.16.2.1 255.255.255.252
pvc 2/2
enca aal5snap
ip as-path access-list 1 permit ^$
router bgp 6500
no synchronization
bgp log-neighbor-changes
neighbor 172.16.100.1 remote-as 100
neighbor 172.16.100.1 ebgp-multihop 2
neighbor 172.16.100.1 update-source Loopback0
neighbor 172.16.200.1 remote-as 200
neighbor 172.16.200.1 ebgp-multihop 2
neighbor 172.16.100.1 filter-list 1 out
neighbor 172.16.200.1 filter-list 1 out
neighbor 172.16.200.1 update-source Loopback0
no auto-summary
ip route 172.16.100.1 255.255.255.255 atm1/0.1
ip route 172.16.200.1 255.255.255.255 atm2/0.1
Please Rate Helpful posts
Best Regards,
Mounir Mohamed
mheusinger
Level 10
Level 10
Hello Jeff,
what type of multi homing are you using. The config provided by Mounir assumes one BGP router connected to one other BGP router through two lines.
Or do you have
1) one BGP router connected to several BGP routers from one ISP
2) several BGP routers connected to several BGP routers from one ISP
3) one BGP router connected to several BGP routers from different ISPs
4) several BGP router connected to several BGP routers from different ISPs
As you might understand there are quite different configs resulting from the different requirements. Can you highlight, which case is close to your design?
Regards, Martin
Hi mheusinger,
i have two options.
1. one bgp router connected to two different isp
2. one bgp router connected to one isp
thanks.
jeff
Dear Jeef,
-the above configuration achive option 2 (One router with 2 ISP's)
-option can be done by using the following config on each router with some ip changes and ASN but also you have to clarify some points A)Are you gone use primary and backup design if Yes so you gone to use a higher local prefernace for the routes that received from the primary provider and run IBGP between both routers
B)Are you gone use Load balance design
c) How about the downstream traffic?
desc ISP 1
pvc 1/1
enca aal5snap
router bgp 6500
no synchronization
no auto-summary
If all that doesn't solve your problem please provide us with full details about your case in order to let the guys to provide you with best solution.
PLease Rate Helpful posts.
Best Regards,
Mounir Mohamed
