BGP Multihoming & single Router, load sharing and automatic fail over
This is my first question on Cisco #Support forum,
I have two ISP connected to my single router R1, R1 is publishing two prefixes, I want to use  prefix A use RCOM ISP and  prefix B use Sify ISP and RCOM should be my Primary ISP for other networks and also configure fail over also.
So please tell me how will i configure same
please find attached screenshot for same.
there a numerous ways to achieve this, AS path prepending is one of them. Post the config of your R1 router, so we can fill in he necessary bits and pieces...
GTR#sh running-config
Building configuration...
Current configuration : 1771 bytes
! Last configuration change at 16:27:15 UTC Fri Mar 2 2018
version 15.2
hostname GTR
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
interface Loopback0
ip address 10.125.73.193 255.255.255.192
interface Loopback1
ip address 10.125.76.129 255.255.255.224
interface Loopback2
ip address 172.16.1.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex full
interface FastEthernet1/0
ip address 191.191.191.41 255.255.255.252
duplex full
interface FastEthernet2/0
ip address 180.180.180.221 255.255.255.252
duplex full
interface FastEthernet3/0
no ip address
shutdown
duplex full
router bgp 65028
bgp log-neighbor-changes
network 10.125.73.192 mask 255.255.255.192
network 10.125.76.128 mask 255.255.255.224
network 172.16.1.0 mask 255.255.255.0
redistribute connected
neighbor 180.180.180.222 remote-as 9583
neighbor 180.180.180.222 distribute-list 10 out
neighbor 191.191.191.42 remote-as 18101
neighbor 191.191.191.42 weight 500
neighbor 191.191.191.42 distribute-list 10 out
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip prefix-list sequence-number
access-list 10 permit 10.125.73.192 0.0.0.63
access-list 10 permit 10.125.76.128 0.0.0.31
access-list 10 permit 172.16.1.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
GTR#
version 15.2
hostname GTR
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
interface Loopback0
interface Loopback1
interface Loopback2
no ip address
shutdown
duplex full
duplex full
duplex full
no ip address
shutdown
duplex full
router bgp 65028
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
GTR#
