BGP network mask missing
abissnetcisco
hello
i have some strange behavior on bgp
i am trying to advertise a network like 192.109.XX.0 mask 255.255.255.0
and when i show run  its like
address-family ipv4
network 192.109.20.0
so the mask doesn't stay there.
and the advertised-routes on neighbor
Network Next Hop Metric LocPrf Weight Path
*> 192.109.xx.0    0.0.0.0     0     32768 i
so no /24
what i am missing
with other prefixes it is OK
regards
I am not really sure what you are after to be honest. I set up two test routers as below, only the non-classful mask only shows up:
R1
interface Loopback1
ip address 10.1.1.1 255.0.0.0
interface Loopback2
ip address 172.16.1.1 255.255.0.0
interface Loopback3
interface Loopback4
ip address 199.199.199.1 255.255.255.128
router bgp 1
bgp log-neighbor-changes
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
network 199.199.199.0 mask 255.255.255.128
neighbor 200.200.200.2 remote-as 1
R1#sh ip bgp topology *
*> 10.0.0.0 0.0.0.0 0 32768 i
*> 172.16.0.0 0.0.0.0 0 32768 i
*> 192.168.1.0 0.0.0.0 0 32768 i
*> 199.199.199.0/25 0.0.0.0 0 32768 i
R2
R2#sh ip route
B 10.0.0.0/8 [200/0] via 200.200.200.1, 00:03:55
B 172.16.0.0/16 [200/0] via 200.200.200.1, 00:03:55
B 192.168.1.0/24 [200/0] via 200.200.200.1, 00:03:55
199.199.199.0/25 is subnetted, 1 subnets
B 199.199.199.0 [200/0] via 200.200.200.1, 00:02:04
200.200.200.0/24 is variably subnetted, 2 subnets, 2 masks
C 200.200.200.0/30 is directly connected, GigabitEthernet0/0
L 200.200.200.2/32 is directly connected, GigabitEthernet0/0
R2#sh ip bgp topology *
*>i 10.0.0.0 200.200.200.1 0 100 0 i
*>i 172.16.0.0 200.200.200.1 0 100 0 i
*>i 192.168.1.0 200.200.200.1 0 100 0 i
*>i 199.199.199.0/25 200.200.200.1 0 100 0 i
7 Replies 7
rais
Level 7
Level 7
This is not an error. Your address is class-C for which mask is /24 by default
HTH.
Jaderson Pessoa
Hello @abissnetcisco ,
this is not a error.
when you see 0.0.0.0  the switch itself is the next-hop to this network. :)
Jaderson Pessoa
*** Rate All Helpful Responses ***
this is not right because should be like
*> 192.109.xx.0/24    0.0.0.0     0     32768 i
this is a bgp advertisement so should be like this to be accepted on public routing.
these are public IP
router bgp xxxxxx
bgp router-id 10.1.10.1
no bgp fast-external-fallover
no bgp default ipv4-unicast
neighbor xxxx remote-as xxxx
neighbor xxxx description xxxx
neighbor xxxx version 4
address-family ipv4
network 192.109.xx.0
network 79.174.xx.0 mask 255.255.255.0
neighbor xxxx activate
neighbor xxxx prefix-list IN in
neighbor xxxx prefix-list OUT out
neighbor xxxx route-map RM-IN in
exit-address-family
how can i advertise with /24 subnet  192.109.xx.0
the other one it is OK
post the full configs of both sides so we can lab this...
hello
i cant send this because the other side is the transit provider
but you can test by typing
router bgp xxxx
network 192.109.xx.0 mask 255.255.255.0
after that do sho run | sec bgp
and you will find
router bgp xxxx
the mask is missing
and the subnet doesn't advertise on provider BGP like xxx/24 but just 192.109.xx.0   (without /24)
R1
interface Loopback1
interface Loopback2
interface Loopback3
interface Loopback4
router bgp 1
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
R2
R2#sh ip route
leave it
it was just useless feature of Cisco (drooping the /24 visually)
i am used seeing that /24 or /xx
i just checked on looking glasses and the prefix is OK on public
sorry  & thank you
