BGP network statement mask issue
hfakoor222
I have a router with Loopback interfaces
when I do my bgp network statement it's not letting me advertise a 192.168.3.1/224 or a 192.168.3.65/192                                    however it is letting me advertise a 192.168.3.0/224 and a 192.168.3.65/192. Can someone explain to me why this behavior is happening? For examp[le I want to advertise the 192.168.3.65/192 routes and not 192.168.3.64/192 so why is it forcing me to choose? Does it have something to do with the prefixing?
If you want to advertise 192.168.3.65 you need to use /32 cause 192.168.3.65 is an IP address and not a network.
 The network is 192.168.3.64/192
Thats why the protocol allow .64 and not .65.
6 Replies 6
the correct statement for BGP route advertisement with network command is as below:
network [subnetwork_ID] mask [subnetwork_mask] , hence the first parameter should be subnetwork_ID, not IP address of interface, but subnetwork ID of the subnet to which interface IP belongs to. Or you may advertise any route from routing table, but again with subnetwork_ID (basically, prefix should be mentioned, not IP address from the range).
In your screen, network 192.168.3.0 mask 255.255.255.224 works, because it is 192.168.3.0/27 which is exact prefix (subnetwork) and its mask.
192.168.3.65 mask 255.255.255.192 which is the same as 192.168.3.65/26 will not work, because it is IP from the range, you should mention the first IP from the range (network ID) - like 192.168.3.64 mask 255.255.255.192.
HTH,
Thank you
This normal , bgp will accept this network only if the mask is 255.255.255.255
You use loopback with 224 and 192'
Check netwrok ID of this subnet/subney mask or you can use
Show ip route check how route inject this subnet in RIB
Use it same as it appear in RIB and bgp will accpet it
I want to advertise specific host from subnet'
Sorry there is no way I know
