bgp network statement
abbek6001
why is it my show IP bgp command does no responsd, what could be the problem?
Richard Burts
You have not given us much detail to work with. Are you sure that it is not responding? Is it possible that it is responding with a null response which says that there is no matching data to display. The sho ip bgp command should display the routes known to BGP. Are you sure that your BGP is learning networks?
Would you post your configuration of BGP and post the output of show ip bgp neighbor and post the output of show ip route
Rick
Rick
Adding to Richard's comment, if you  are using MP-BGP under MPLS environment you will see nothing until you execute:
show bgp vpnv4 unicast all summary
Also if there are no any peer you will not see anything.
Also remember that when you are advertising a subnet or host through BGP you must include the exact subnet mask otherwise it will not be advertised. Example:
interface loopback 0
ip add 1.1.1.1 255.255.255.255
router bgp 100
network 1.1.1.1 mask 255.255.255.255
Please share your config and topology. Thanks.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
