03-09-2017 11:29 AM - edited 03-05-2019 08:10 AM
is it possible to use the SFP-Port as LAN-Port?
Thank you
03-09-2017 12:14 PM
Yes you can use a SFP for LAN port, I think you want it to connect a PC or server, right? so you should use a SFP for copper like GLC-T
Platform Support
Table 2 describes the interfaces, Wi-Fi options, and integrated capabilities supported by each of the Cisco 890 Series ISR models. May I know how have you planned to use it?
Table 2. Platform Support for 890 Series ISRs
Model |
WAN Interfaces |
Integrated Dial Backup |
Cisco 892FSP |
1-port GE or 1‑port SFP 1-port GE |
8-port 10-/100-/1000-Mbps managed switch |
No |
Yes |
No |
Cisco 896VA |
1-port GE or 1‑port SFP VDSL/ADSL2+ Annex B |
8-port 10-/100-/1000-Mbps managed switch (4‑ports PoE capable with 125W power supply adapter) |
No |
Yes |
ISDN |
Supported SFP Types on the Cisco 892F Series and Cisco 892FSP, 896VA, 897VA, 897VAB, 898EA, 891F |
GLC-LH-SM |
1000BASE-LX/LHSFP transceiver module for MMF and SMF, 1300-nm wavelength, dual LC/PC connector |
GLC-SX-MM |
1000BASE-SXSFP transceiver module for MMF, 850-nm wavelength, dual LC/PC connector |
GLC-ZX-SM |
1000BASE-ZXSFP transceiver module for SMF, 1550-nm wavelength, dual LC/PC connector |
GLC-BX-D |
1000BASE-BX10SFP module for single-strand SMF, 1490-nm TX/1310-nm RX wavelength, single LC/PC connector |
GLC-BX-U |
1000BASE-BX10SFP module for single-strand SMF, 1310-nm TX/1490-nm RX wavelength, single LC/PC connector |
GLC-T |
1000BASE-T standard |
GLC-GE-100FX |
Cisco 100BASE-FX SFP for Gigabit Ethernet SFP ports with multimode fiber-optic (MMF) link |
GLC-FE-100LX |
Cisco 100BASE-LX10SFP with single-mode fiber-optic (SMF) link |
GLC-FE-100BX-U |
100BASE-BX10-U SFP module for 100-MB ports, 1310 nm TX/1550 nm RX wavelength, 10 km over single-strand SMF |
GLC-FE-100BX-D |
100BASE-BX10-D SFP module for 100-MB ports, 1550 nm TX/1310 nm RX wavelength, 10 km over single-strand SMF |
CWDM-SFP-1470= |
Cisco Coarse-Wavelength Division Multiplexing (CWDM) 1470-nm SFP Gigabit Ethernet and 1G/2G fibre Channel |
GLC-LH-SMD* |
1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength |
GLC-ZX-SMD* |
1000BASE-ZX SFP transceiver module for SMF, 1550-nm wavelength, dual LC/PC connector |
GLC-EX-SMD* |
1000BASE-EX SFP transceiver module for SMF, 1310-nm wavelength |
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
