06-21-2022
11:53 AM
- last edited on
06-21-2022
02:30 PM
by
Translator
06-21-2022
12:20 PM
- last edited on
06-21-2022
02:36 PM
by
Translator
But i think you can use
route-map
Match prefix
Match next-hop
Set administrative distance
This workaround but i think it can work.
06-21-2022
12:17 PM
- last edited on
06-21-2022
02:32 PM
by
Translator
Bgp backdoor
can not config in nexus as i know.
06-21-2022
12:20 PM
- last edited on
06-21-2022
02:36 PM
by
Translator
route-map
Match prefix
Match next-hop
06-21-2022 07:10 PM
could you please share the command , i used the below route-map command for inbound .
the metric doesn't change .
route-map IBM-TO-BGP permit 10
set local-preference 75
set distance 200
neighbor 10.30.40.1
remote-as 65003
address-family ipv4 unicast
route-map IBM-TO-BGP in
06-22-2022 05:10 AM
can you check the table-map set distance.
