BGP not advertised
I have two routers with BGP configured:
C2921:
router bgp 65014
 bgp router-id 192.168.54.190
 bgp log-neighbor-change
 neighbor 192.168.54.150 remote-as 65011
 neighbor 192.168.54.150 description Loud backup
 neighbor 192.168.54.150 route-map Backup out
C1841:
router bgp 65011
 no synchronization
 bgp router-id 10.10.35.1
 bgp log-neighbor-changes
 neighbor 192.168.54.149 remote-as 65014
 neighbor 192.168.54.149 description Cubus backup
 neighbor 192.168.54.149 prefix-list Loudenia out
 neighbor 192.168.54.149 route-map Backup out
ip prefix-list Loudenia seq 5 permit 10.10.35.0/24 le 32
ip prefix-list Loudenia seq 10 permit 192.168.111.0/24 le 32
ip prefix-list Loudenia seq 15 permit 10.25.15.0/24 le 32
ip prefix-list Loudenia seq 20 permit 192.168.44.0/24 le 32
ip prefix-list Loudenia seq 25 permit 192.168.45.0/24 le 32
ip prefix-list Loudenia seq 30 permit 192.168.46.0/28 le 32
ip prefix-list Loudenia seq 35 permit 192.168.49.196/30 le 32
ip prefix-list Loudenia seq 40 permit 192.168.49.225/32
ip prefix-list Loudenia seq 45 permit 192.168.49.229/32
route-map Backup permit 10
 set as-path prepend 65011 65011
I have added:
ip prefix-list Loudenia seq 50 permit 192.168.48.225/32
made:
clear ip bgp 192.168.54.149 soft
but nothing changed route to 192.168.48.225 not advertised:
C1841-Loudenia#show ip bgp neighbors 192.168.54.149 advertised-routes
BGP table version is 137998, local router ID is 10.10.35.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.10.35.0/24    0.0.0.0                  0         32768 i
*> 10.25.15.0/24    192.168.111.10           0         32768 i
*> 192.168.44.0     192.168.49.26                          0 65005 i
*> 192.168.45.0     192.168.49.26                          0 65005 i
*> 192.168.46.0/28  192.168.49.26                          0 65005 i
*> 192.168.49.196/30
*> 192.168.49.225/32
                    192.168.49.26            0             0 65005 i
*> 192.168.49.229/32
*> 192.168.111.0    0.0.0.0                  0         32768 i
C1841 knows 192.168.48.225/32 via bgp
*  192.168.48.225/32
                    192.168.49.58                          0 65005 65005 65005 65006 65013 i
*>                  192.168.49.26                          0 65005 65006 65013 i
I will be grateful for your advice
Hello
Do you have this host route in the rib of the 1841 for it to be advertised?
res
Paul
Kind Regards
Paul
Thanks  for reply. Paul how can I check it?
That is you mean?
*  192.168.48.225/32
Tagir Temirgaliyev
C1841:
router bgp 65011
network 192.168.48.225 255.255.255.255
you need also static route
ip route 192.168.48.225 255.255.255.255  ....
