BGP order for prefix-lists AND route-maps
General question about BGP.
Taking this config:
neighbor 1.1.1.1 prefix-list MY_PREFIX_LIST in
neighbor 1.1.1.1 route-map MY_ROUTE_MAP in
route-map MY_ROUTE_MAP permit 10
 set local-pref 110
ip prefix-list MY_PREFIX_LIST seq 5 deny 2.2.2.2/32
ip prefix-list MY_PREFIX_LIST seq 10 permit 0.0.0.0/0 le 32
If 1.1.1.1 advertises the 2.2.2.2 prefix, it will be permitted (and local pref set to 110) because inbound route-maps are processed first (and of course the lack of a match statement indicates match-all). Correct?
Or am I misunderstanding this page?
Peter Paluch
Hi Steven,
The BGP FAQ document you're referencing should be the authoritative guide. So for inbound routes, first the route-map, then the prefix-list are evaluated - that's correct. But my understanding is different: The route-map is the first filter, and whatever remains after passing through the route-map is additionally subjected to the prefix-list. A route will be accepted only if it is permitted both by the route-map and the prefix-list - it has to pass both.
So in this logic, the 2.2.2.2/32 should not be accepted because even though it has made it through the route-map, the prefix-list drops it explicitly.
Would that match your observations?
Best regards,
Peter
Peter Paluch
Hi Steven,
Best regards,
Peter
Hi Peter,
Thanks for that. I just labbed this up and confirmed that the behavior is exactly as you've described.
Cheers,
Steve
