BGP path selection issue with AS prepend
Najib Akbari
I have site ASA 1.1.1.1 and tunneled with static route to two Fortigate FW1 and FW2. each FW linked to LAN via Core SW -> VeloCloud SD-WAN, so both FW 1&2 has BGP neighborship with Core SW and Core SW with VeloCLoud A and B and to make A path less preferable I prepend the ASA subnet 192.168.168.0/24 ( redistributed as static into BGP ) route with FW1 ASN so from C prespective, the route from B path be more preferable but C site Core switch BGP prefers A even though it has longer AS-Path. i have limited knowledge of Velo-Clouds and i checked BGP settings on core switches and fortigate and no other attributes are affecting best-path decision unless something going on on VeloCloud and i do not know how to check. please advise
attached is the topology
29 Replies 29
Hello
Given where as-path is situated in bgp best selection, Its entirely possible that the Velocloud could is overwriting the as path-prepend when its receiving the prefixes from you?
Kind Regards
Paul
Yes it is possible. I did AS-Path prepend on site A core switch BGP outgoing adv towards VCloud
Hello
You could possibly have a word with your ISP for the vcloud and see if that is the case, maybe they are expecting communities?
Another option you can control would be to summarise on the less desirable path and advertise more specific prefixes on the preferred path?
Kind Regards
Paul
summarize will work, but i was wondering if i can fix it with BGP attributes. I have admin access to VeloClouds but i need guidance how to verify it. when i do sh ip bgp on core switch it does not show both records from two different source of advertisement routers, it seems then VCloud does sort of filter and relay only one route, if that source stops/fils then relays the other one but always prefers the one coming from site A ( what do you think? )
can you elaborate on communities maybe? how do i verify and maybe use it
Hello
you dont mention what the Velocloud is, however maybe you can verify the bgp process configuration, do you see any attributes being applied that can negate ingress route prefixes pertaining to as-path prepending
Kind Regards
Paul
VCloud is VMWARE SD-WAN appliances managed by ATT and I have admin access
MHM
Yes, two VTI tunnel going to FW 1&2. No BGP on ASA. with static route higher metric on traffic going to FW1 so makes FW2 primary link from ASA point of view
MHM
MHM
no, different AS # and yes i am aware of that, thnx
MHM
Velo does not remove private AS#, it always relays the route learned from Site A even thu sh ip bgp shows prepended AS #.
on your second though of summary and small prefix, thats different approach of forcing certain path with most specific and that already discussed in this case, thats feasible but i want to do it with BGP.
MHM
