BGP Path Selection
Making some BGP labs, I found this BGP decision to select a best route to 10.10.10.10:
R8#sh ip bgp vpnv4 vrf call 10.10.10.10
BGP routing table entry for 1:100:10.10.10.10/32, version 33
Paths: (3 available, best #2, table call)
  Advertised to non peer-group peers:
  5.5.5.5 6.6.6.6
  65400
    3.3.3.3 (metric 3) from 5.5.5.5 (5.5.5.5)
      Origin IGP, metric 10, localpref 100, valid, internal
      Extended Community: RT:1:100 RT:2:100
      Originator: 3.3.3.3, Cluster list: 5.5.5.5
  65401
    10.0.89.9 from 10.0.89.9 (9.9.9.9)
      Origin IGP, metric 100, localpref 100, valid, external, best
  65400
    3.3.3.3 (metric 3) from 6.6.6.6 (6.6.6.6)
      Originator: 3.3.3.3, Cluster list: 6.6.6.6
I hoped that changing metric to 100 from 10.0.89.9, the router will prefer the other routes but not. I have to change local preference to do that. From the above output, I would like to know which atrubute is using BGP to select the route ( I think 3. locally originated, but this router is learning the prefix via eBGP). The weight has not been modified.
BGP table version is 40, local router ID is 8.8.8.8
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:100 (default for vrf call)
*>i1.1.1.1/32       2.2.2.2                  0    100      0 65400 i
* i                 2.2.2.2                  0    100      0 65400 i
* i4.4.4.4/32       3.3.3.3                  0    100      0 65400 i
*>i                 3.3.3.3                  0    100      0 65400 i
*> 9.9.9.9/32       10.0.89.9                0             0 65401 i
*>i10.0.14.0/24     3.3.3.3                  0    100      0 65400 i
* i                 3.3.3.3                  0    100      0 65400 i
* i10.10.10.10/32   3.3.3.3                  0    100      0 65400 i
*>                  10.0.89.9              100             0 65401 i
Thanks.
vanoordtm
Community Member
It looks to me the route is selected based on  rule 7 of the bgp best path selection, which is external over internal.  Why? Because Med is only considered if the first AS matches or BGP always-compare-med is applied.
Hello.
Please refer http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13753-25.html
You may configure an option to compare MED for different AS-es.
